leakdown and compression test numbers?
Anyone know what are good/bad numbers for c5 motors? Mine is a '99 LS1 with roughly 30k miles. I tested my motor and the leak down came in the 11%-16% range. Compression came in at 180-235 range (bank 2 compression test, passenger side, showed much better numbers than bank 1). Keep in mind that I did it on a cold motor (don't currently have radiator).
thanks,
-V
thanks,
-V
You basically want to see right around 8%. Up to 12% is ok for a higher mileage car. After that it's not good. 16% is a little poor but you also said the car wasn't warm.
If you squirt a little oil down in there you'll know if it's the ring. Sometimes it can be something in the cylinder heads.
Hope this helps,
Mike
Hope this helps,
Mike
It's actually 24% variance. For some reason I thought 180-200 was considered good. It's been some time so I really am not sure. Considering this was all done cold I am ok with my leakdown numbers. The compression test kind of concerns me.
