Coleman rotors and Cobalt Pads Bedding Question
Can anyone provide some information. I installed a set of Coleman rotors and Cobalt CRB GTS pads on my C6Z06 front and rear for track use. I drove around for a little while normally and then did the old bedding routine, 60 down to 10mph 8 times, then drove to let them cool and put the car in the garage. These things SQUEAL like a stuck pig but stop great. Is this enough for the track as far as bedding? P.S. I've never seen a pad create so much break dust in such a short period of time
coblat frictions do not require bedding as i have read on here many times.
dont worry they last a long time!!! i have had mine on for 50-60 20 minute sessions and still are around 1/4 of the pad life left
i have coleman all the way around and xr1 pads
Thanks to Bob at AFX Performance.
Thanks, I did a search and others stated they squeal loudly also, I could care less about this because they're for the track. Just wanted to make sure if this is the norm. Others said that break dust is 50% more than stock, again I'm ok with it. I'll just wash it off after the events. I removed the caliper spring clips and haven't had a problem.
Thanks, everything is together for the track and I'm to lazy to lift the car and do it again next time I'll put in the clips. For now everyone else will have to live with the noise Thanks for the help
