Question/ hpde & airbags
Old 07-10-2009, 06:56 PM
shifter77
shifter77's Avatar
Default Question/ hpde & airbags
Is it possible to disconnect airbags (fuse) for track events??
Old 07-10-2009, 07:52 PM
CHJ In Virginia
CHJ In Virginia's Avatar
It is possible to deactivate the airbags by selective wire modifications. Why would you want to deactivate them ?? If I end up nose first in a tire wall, I want every safety function I can get in addition to the harnesses, HANS, etc.
Old 07-10-2009, 08:17 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
yes althought I have no proof I have no fuse. Minor bump will cause you to lose your windshield. All a personal choice to decide on safety and how your car is setup.
Old 07-10-2009, 08:38 PM
Dreamin
Dreamin's Avatar
Someone posted pretty compelling arguments for NOT running airbags with a 5/6 point harness.
Gary (hardbar) maybe??
Old 07-11-2009, 08:12 AM
AU N EGL
AU N EGL's Avatar
if you vette has a warranty and or you think you might use the warranty, you may wish to think twice about disconnecting the air bags.
that information is stored in history. when a dealer plug in their tech II, they will know.
PLUS if you have On-star, the disconnect code may be transmitted to On-Star
Now if you dont care about your warranty, put in aftermarkest seats, harness bar and 6 points
Old 07-11-2009, 08:30 AM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
The more soft things there are to hit inside the car, the better.
Old 07-11-2009, 01:19 PM
Bill Dearborn
Bill Dearborn's Avatar
Received 8,928 Likes on 5,333 Posts
John,
I have seen a number of cars that had the air bags go off without breaking the windshield. There have even been some pictures of C5s in the For Sale section that had their air bags deployed and the windshield was still in good condition.
Bill
To Question/ hpde & airbags
Quick Reply: Question/ hpde & airbags
