Wtb/ small tire trailer
Old 07-08-2009, 05:08 PM
shifter77
shifter77's Avatar
Default Wtb/ small tire trailer
Can anyone direct me where to find 1 or buy 1.
Old 07-08-2009, 05:48 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
northern tool/tractor supply/lowes has them. Is that not what you are looking for??
Old 07-08-2009, 05:57 PM
jaa1992
jaa1992's Avatar
Location: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps GA
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Also Harbor Freight, the small one fits 4 315 wide tires and a small truck box.
You have to put it together and add the deck and box.
Old 07-08-2009, 06:05 PM
shifter77
shifter77's Avatar
Thanks for the tip. Will check it out.
Old 07-08-2009, 08:47 PM
davidfarmer
yes, I have all four of those stores within a stones throw of my house.........I wonder how many of those trailers I could fit INSIDE of my 24' featherlite??
Old 07-08-2009, 09:35 PM
CHJ In Virginia
CHJ In Virginia's Avatar
The trailers usually come with two sizes of wheel/ tire - 8" or 12".. Spend the extra $50 and get the larger tire / wheel combo. If you are going to drive any distance it greatly reduces the speed of wheel and bearing wear for the trailer. There are several hitches that will fit a C5 Vette that conceal the tongue between the exhaust and you can not see it.
Old 07-08-2009, 11:44 PM
johninar
johninar's Avatar
I agree with the 12" tires.
Mine came from Tractor Supply.
Old 07-09-2009, 07:51 AM
shifter77
shifter77's Avatar
Thats axactly what i need JOHNINAR. Would you happen to have trailer style #?
Old 07-09-2009, 08:05 AM
igo380
igo380's Avatar
Is there a hitch that fits a c6 as well as a C5?
Old 07-09-2009, 09:34 AM
AverageVetteNut
AverageVetteNut's Avatar
Cruise-In 9-10 Veteran
CI-X Auto-X Champ (race tires)
St. Jude Donor '07-'09
that's the 4x6 tilt bed trailer... retails here in PA for $349 @ TSC. I got the same one, and added mounts for the tires.
Works great. Bought a truck box there for $89 and attached it to the floor as well.
Old 07-09-2009, 03:16 PM
shifter77
shifter77's Avatar
Would UHAUL be a good choice to install a hitch?? Just called them they dont make a hitch for a vette.
HELP please.
Old 07-09-2009, 03:38 PM
drivinhard
drivinhard's Avatar
Originally Posted by johninar
What track is that? I don't recognize it. Hallet?
I have the exact same trailer. Works great. I have pulled it as far as MI with the Z06.
I got a hitch from etrailer.com. I think it was a drawtite, can't remember
Old 07-09-2009, 04:57 PM
johninar
johninar's Avatar
Sorry for the delay. Yes it's a Tractor Supply 4x6 tilt trailer with 12" wheels. I use a Draw-Tite 1" mini receiver hitch. Pulls great.
Hallett it is. I really like the track, just wish it was closer.
http://www.hallettracing.net/
Old 07-09-2009, 05:51 PM
shifter77
shifter77's Avatar
Just received updated info from UHAUL, they do make a hitch for the C6 Wondering if that same hitch would fit on the C6ZO6?
Has anyone attached a hitch on their aluminium frame?
BTW , HALLETT looks like a fun track.
Old 07-09-2009, 08:23 PM
johninar
johninar's Avatar
Last time I checked, Draw-Tite would not certify any C6. That's always subject to change of course. I doubt Draw-Tite would ever certify a hitch for the C6 Z06. I had a Draw-Tite distributorship many years ago, they are too conservative for that fit. Is the U-Haul a Curt hitch? I'm sure someone here knows if the C6 translates to a Z.
Interesting thing about Hallett. A Russian named Anatoly Aruntunoff who was in the 1975 & 79 running of the Cannonball coast to coast run built Hallett in 1976.
Old 07-09-2009, 09:02 PM
*C7*
*C7*'s Avatar
St. Jude Donor 05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
A C6 hitch will not fit on a Z06 without some modification. If you do a search you will find a few threads on Z06 hitches.
Some are made from scratch and others are C6 hitches that are modified.
There are proably atleast 6 of us that have them on a Z06......
Old 07-10-2009, 11:06 AM
bobmoore2
bobmoore2's Avatar
Here's some info on a C6 hitch and where to get it.
http://forums.corvetteforum.com/auto...ler-hitch.html
http://www.autoanything.com/towing/7...0A2658889.aspx
http://www.etrailer.com/hitch-2006_C...t_Corvette.htm
To Wtb/ small tire trailer
Old 07-10-2009, 02:49 PM
beerkat
beerkat's Avatar
You might want to get a spare for the trailer also.
Old 07-10-2009, 05:29 PM
shifter77
shifter77's Avatar
Lots of great info, but still confused what trailer hitch to get & would i need to modify to hitch to fit my c6zo6.
Will the ETRAILER hitch fit the c6zo6??
Old 07-13-2009, 10:28 AM
Jim 47
Jim 47's Avatar
Give me a holler: I've got a custom made welded all steel tire trailer with an aluminum tool box attached. Has 13+" wheels with spair wheels and tires, lockable tire rack. I had it built for my C5 and it's been used over the past 8 years. Still in great shape. 0 to 60 in about 5.0 sec!! jaslhelm1@verizon.net Everything is negotiable .
Quick Reply: Wtb/ small tire trailer
