VBP vs pfadt poly bushing kit c6z
Old 07-01-2009, 06:10 PM
dvandentop
dvandentop's Avatar
Default VBP vs pfadt poly bushing kit c6z
anyone know the differences between the 2 of them??
The VBP i can get for $369 - 20% $295.20 total due to a forum special
the Pfadt is $490.
thanks for the help
Old 07-01-2009, 06:30 PM
mountainbiker2
mountainbiker2's Avatar
On my C5 I liked the VBP ones. I tried another brand and disliked them some much I cut them out and sent them back.
Steve
Old 07-01-2009, 08:21 PM
gonzalezfj
gonzalezfj's Avatar
the Pfadt is $490.
thanks for the help
Derek, I just got my C6Z control arms back from Pfadt with the new poly bushings installed.
I haven't installed them yet, but they certainly look like works of art. Great design and execution. Make sure you look these over before you make a decision to buy.
Frank Gonzalez
Old 07-01-2009, 09:33 PM
ghoffman
ghoffman's Avatar
Cruise-In II Veteran
There was a very long thread on this exact subject, just a couple of weeks ago. It had many posts on experiences with both.
Old 07-01-2009, 11:04 PM
dvandentop
dvandentop's Avatar
got a link at all?
i searched in here and couldnt find it
Old 07-01-2009, 11:07 PM
dvandentop
dvandentop's Avatar
found it thanks for the tip gary
http://forums.corvetteforum.com/auto...-bushings.html
Old 07-02-2009, 05:31 AM
GrantB
GrantB's Avatar
I've had both on my car.
Summary:
Pfadt's sleeves are aluminum. This binds to the urethane less than the VB&P's steel sleeves, and is a few pounds lighter. Pfadts also have grooves cut into the inside of the bushings to hold more grease, and in my experience this translates into lubrication lasting much longer.
If there are advantages to the VB&Ps over the Pfadts, I don't know what they are.
Old 07-02-2009, 01:40 PM
wmckeenster
wmckeenster's Avatar
If you want performance AND reliability, Pfadt's all the way!.......and I have had both
Old 07-02-2009, 04:00 PM
dvandentop
dvandentop's Avatar
damn i am having alot of conflicting reports where one has had problems or the other has
anyone know the part # for t1 supper a arms?? are those alot better then stock?
Old 07-02-2009, 04:36 PM
trackboss
trackboss's Avatar
The VBP ones are much harder urethane than the prothane from pfadt. I have pfadts on my front uppers. They have quite a bit of slop. Either the cross shafts need more material on the side or the bushings need to be thicker. The pfadts are single piece and need to be pressed in where as the VBP are two piece so they go in a bit easier. I'd say that the VBP have less deflection because of the higher durometer material, but on the rear lowers and front uppers a bit more bind for the same reason. Lube should take care of it.
Old 07-02-2009, 05:00 PM
mountainbiker2
Look at the sleeves that Pfadt use. On the lower a arms they have a sleeve with a washer attached to the sleeve. That's great, but the other side you install a loose washer. So you have a lot of surface area on one side and hardly any on the other side. Basically just the little round sleeve. Which by the way almost hardly touches anything on your frame. That's because there is a big oval hole for you to adjust your camber or castor. I think you guys that look at it carefully will understand what I'm talking about. This only applies to the lower a arms. The upper ones are okay. VBP uses two piece sleeves with washers attach to them for much better surface area.
Frank talks about a new design from Pfadt. That I have no idea about.
Steve
Old 07-02-2009, 05:06 PM
dvandentop
dvandentop's Avatar
Damn deicisions decisions, or maybe i should just get some t1 upper fronts for now.
still drive on the street every once in a while but not near as much as before i went mod crazy with the cam etc...
Old 07-02-2009, 06:03 PM
GrantB
GrantB's Avatar
I'd forgotten about the VB&Ps being harder. This is true. I didn't have grease zerks in my VB&P, so wasn't able to lube them easily after install. Unless you cut grooves in the VB&Ps, their lube will run out much sooner than the Pfadts.
Maybe I have the "newer" Pfadts, but my front uppers didn't have any more slop than my VB&Ps. When bolting down the upper A-arm on the VB&Ps and the Pfadts, I bent the upper wishbones inwards a bit to keep the arm from being able to walk forward and backward on the bushing.
Old 07-02-2009, 06:05 PM
dvandentop
dvandentop's Avatar
any pics of the grooves on either pfadt or vbp?
Old 07-02-2009, 06:07 PM
GrantB
GrantB's Avatar
Sorry, I didn't take any pics. But there aren't any grooves in the VB&Ps unless you cut them in there yourself.
Old 07-02-2009, 06:10 PM
dvandentop
dvandentop's Avatar
verticle or horizontal wise?
how many would you say in each bushing?
Old 07-02-2009, 08:32 PM
gonzalezfj
gonzalezfj's Avatar
My Pfadts have 8 grooves cut longitudinally along the entire length of each bushing. They are about 1/16" x 1/16" and full of lubricant.
I will be installing them (front upper control arms) on the car tomorrow and testing them at NJMP on the 4th.
I will be able to give you more details then.
Frank Gonzalez
To VBP vs pfadt poly bushing kit c6z
Old 07-02-2009, 08:35 PM
dvandentop
dvandentop's Avatar
looking forward to hearing about it frank, did you front bushings have issues sliding as well?
Old 07-03-2009, 05:34 PM
dvandentop
dvandentop's Avatar
well i just ordered some vbp ones this morning since they were doing 20% off and also i figure the t1 uppers would push out eventually also.
so i guess i will see what happens and how they work
Old 07-04-2009, 08:17 AM
GrantB
GrantB's Avatar
Does anyone have any pics of where they put grease zerks in these things? I've got my front suspension apart so I figured I'd add them, but I'm a little wary of weakening the control arms or adding stress risers. Is this fear warranted?
Quick Reply: VBP vs pfadt poly bushing kit c6z
