New from Hardbar, spherical Delrin pin top shock mounts
1 Post
Cruise-In II Veteran
This is the first and only truly correct mount for "pin top" shocks. They are CNC billet DuPont Delrin and stainless steel and will allow your shocks to have correct damping without the rubber and it still allows angular deflection of the shock as it goes through its' motion with virtually zero side load on the shock. Unlike some others, this is spherical on the top and bottom so it works with stock or coil-over shocks. Tested on Penske, Bilstein, Sachs (OE Corvette) shocks but will fit any shock with a 10mm upper pin top. The price is for an entire car set, $240. Better performance, better shock life, totally quiet for street or track use. In stock for immediate delivery.
The gold colored plate not included.
http://hardbarusa.com/hardbar/produc...roducts_id=141
Former Vendor
1 Post
Are you suggesting that a C2 and C3 Corvette guy actually drill out the holes to .85"
Ahhh, I made you laugh. Didn't I?
Keep up the good work.
That is wht we will be putting on top of Gerrald's Penske's and Dave's Eibach/Calloway's
Mark
PS. I got to tour Penske Racing South race shop outside of Charlotte on Monday. It is unbelievable!
Gary's shock mounts
Hi all,
I'm local to Gary. He asked me to test a prototype version of these mounts on my 02 Z06. So I thought I would post my impressions. This is unprompted by Gary, BTW. I'm just doing what I can to help out.
The car--It's a pretty mild setup. Bilstein sports, T1 bars, poly bushings. Pretty much all I do with it is autocross it. It gets flogged very often and very hard.
I've done three or four autocrosses and an Evo School with the mounts.
The mounts--They simply work as advertised.
They have performed well, just like Gary said they would. I have noticed that the front end responds very well to inputs. The most telling thing, I felt, was when a friend and longtime autocrosser -- a guy whose opinion I really respect -- drove my car and another Z06 (a 2003) back-to-back at an autocross a couple weeks ago. This friend, said that my car turned in much harder.
Note: My car and this 03 are setup almost exactly the same. Same Bilstein sport shocks, same T1 bars, same alignment. The 03 has with poly shock mount bushings and stock rubber control arm bushings vs. my poly control arm bushings and Hardbar shock mounts. Also, both cars were on FRESH (0-10 runs) Kumho V710s.
The mounts are also quiet on the highway. I didn't notice any real increase in NHV type noises. (And if you're a waxer, you shouldn't be buying these parts anyway. :-P )
So there you go. I am posting my impressions because I want to try to help out Gary since he's been really helpful to me in getting my car set up well.
I can try to answer any other questions people might have.
-John
02 Z06
-John
02 Z06
Having the spherical on the top AND bottom really sets these apart.
Allowing the coilover to rotate properly takes away some of the huge side forces which can cause issues.
Well done Gary
Well done Gary
1 Post
Thanks guys! It has been a long time in development. The prototypes just had a rubber washer made from an old inner tube, but the production version shown has a fiber reinforced rubber washer for NVH and also to allow adequate preload on the nut. The damn rubber washer was the hardest part to get made! The nut needs to be torqued to 1/2 turn after everything is in contact. I think there will be a short break in period, then check the nut for torque then forget about it. The local tire shop that does my Hoosiers loves this for trick pickup truck suspensions as well! I figure I will get a ration of comments about clevis mounts, which I still prefer, but there are many, many times more pin top shocks out there so this is a very close second in performance. As Mike said, this is spherical on the top and bottom so that you guys with the leaf springs are taken care of! See, I can make normal stuff too, not just big buck things!
Thanks!
Stan
just installed these, they are true works or art, me stock bilstein rear bushings were real bad, these are a must do upgrade as i am pretty sure i was getting tons fo deflection in my stock bilstein upper mounts, as the rears were nearly pancaked in some areas, the fronts were not near as bad but i did the complete set.
1 Post
Correct geometry, and they are spherical top and bottom. With coil overs, you can get away with spherical on the bottom only because the loads are always loading the bottom surface. For leaf spring cars, you need it spherical top and bottom, because the spring pulls the shock down, loading the upper surface. In addition, these look stock which helps depending on what class you run in. These are are an OE replacement part for trucks and SUV's too! We just installed some on a Chevy Silverado with some DRM Bilsteins! The others have a minimum pin length of 2.25 which precludes Penskes and others, wheras these can go down to under 2 inch.
