Autocross with an A4?
Old 06-22-2009, 09:44 PM
minitech
minitech's Avatar
Default Autocross with an A4?
So what is best with an A4? Leave it in 3rd? Just leave it in drive? I know probably a simple question.
Old 06-22-2009, 10:03 PM
NASCAR314
NASCAR314's Avatar
Depends on what type of track / autocross layout, and rear end gear ratio on your car.
Typical autocross I would shift manually between 1st and 2nd as needed. 3rd would rarely be needed in a normal autocross
Some smaller, tight, tracks layouts you can run the whole thing in 1st gear depending on how tall your rear gears are.
Old 06-22-2009, 10:18 PM
minitech
minitech's Avatar
This is the track type I am talking about.
http://www.grattanraceway.com/
Have 4.10 gears.
Old 06-23-2009, 11:35 AM
jaa1992
jaa1992's Avatar
Location: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps GA
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
OK, so this is a road course not an autocross?
When I had my 88 Auto on an autocross I kept it in 2, 2 is good for up to 90MPH in the 88.
Should be close for your car as well even with the 4:10's
Road course is a different animal, depending on the turns and how much you brake determines your gear selection. I have my students keep it in 3 (D, not OD) for a few laps to see where the car tries to kick down. Next time under braking I have them slip it into 2 and back to 3 after track out.
Old 06-23-2009, 08:43 PM
minitech
minitech's Avatar
Thanks for the reply. I'm really new to this whole thing but like the idea of driving on a track. I went on the Waterford Hills track with an instructor in my car that is a similar style as Grattan. What fun! I want to be more involved with doing that with my car.
Question: What type of track is this. Not auto cross? Would I say I am just driving a track? Or on a _______ track? I know it is probably the most basic question.
Old 06-30-2009, 08:24 AM
astock165
astock165's Avatar
Originally Posted by minitech
Not auto cross?
Correct, NOT an autocross. Autocrosses are set up on large (typically flat) paved/concrete surfaces with cones to designate the course and the course changes from event to event.
Yes. And most people who aren't involved with the sport will assume that you're "racing" when you say that, which isn't true either but explaining the difference is
Old 06-30-2009, 10:03 AM
Aardwolf
Aardwolf's Avatar
Race track yes. These tracks are called road courses.
http://en.wikipedia.org/wiki/Road_course
To Autocross with an A4?
Quick Reply: Autocross with an A4?
