Best way to figure out which endlink/rod-end is noisy?
What's the preferred method to figure out which swaybar endlink is noisy? Or which rod-end of which endlink? There's got to be something better than randomly swapping pieces...
With vehical sitting on the pavement(not jacked up),Crawl under each corner and hit sway bar links with rubber mallet.If one is going away,soon they all will be history.Replace both ends if one is bad.
Click the link
http://www.powergridinc.com/
I have them and they work great on my Pfadt bars (though the fronts only got about 4 threads engaged because of the thicker arms on the Pfadts, so I'm not sure if they're safe like that).
