NASA Time Trial Question
Old 06-16-2009, 09:51 AM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
Default NASA Time Trial Question
just looking for a little confirmation, does NASA TT still allow completely stock street cars, with no safety equipment??? Basically just go through HPDE tech, then hit the track????
Reading the rules, it looks like the Recommend a fire extinguisher, and you need a transponder, but otherwise just run???
Also, looks like the C6Z06 would run in TTU....anyone confirm that??? Looks like it would take nearly 600hp to run TTR.
Thanks!
Old 06-16-2009, 09:53 AM
drivinhard
drivinhard's Avatar
pretty much
Old 06-16-2009, 09:58 AM
L98Terror
L98Terror's Avatar
W. Detroit Events Coordinator
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VII Autocross Champ
You are correct sir, TT is set up for street cars
Old 06-16-2009, 10:04 AM
beerkat
beerkat's Avatar
Varkwso can answer all you questions about NASA TT. I know that you need a check ride but I doubt that is an issue for you.
Old 06-16-2009, 10:06 AM
wallyman424
wallyman424's Avatar
I would fall down laughing if the TT director made david do a check ride.
Old 06-16-2009, 10:27 AM
Cobra4B
Cobra4B's Avatar
CI 3-5-6-7-8 Veteran
I'm signed up for TTS next month at VIR
Old 06-16-2009, 10:28 AM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
Nothing more required than HPDE tech.
Old 06-16-2009, 10:29 AM
L98Terror
L98Terror's Avatar
I would expect a check ride but I would if he failed.
Old 06-16-2009, 11:09 AM
davidfarmer
I have a NASA competition license, and have run TT in my race cars, but was thinking of taking the Z06 to Lowes.............however I need a sponsor to pay my $200 entry fee
I live 4 miles from Lows, so I hate to miss it.
Old 06-16-2009, 11:15 AM
The Spark
The Spark's Avatar
This year in Texas Region they issued us TT'ers a log book and we go through tech at the beginning of the year. After that we take our log book and a HPDE tech sheet to tech and they sign off and give us a tech sticker. We don't have to take our cars through.
This past weekend they didn't have enough cars for seperate TT so they put us in with DE cars. But it worked out ok. The DE guys saw us coming and got out of the way most of the time.
My first time to run TT last year, they didn't require a check ride.
May be different in other regions.
Old 06-16-2009, 12:29 PM
davidfarmer
yes, I saw that about optionally doing an annual tech...... that's a great option, and would be great if they did it for DE as well (at least one of my local clubs does, and it's very handy)
Again, I have a NASA license, so no "check ride" should be required.
So anybody confirm the classing. It's completely stock except for tires and brakes. It's just for fun, but I prefer to work it out BEFORE getting protested!
Old 06-16-2009, 12:33 PM
wallyman424
if its a stock Z you'll be in TTU, however they will require a dyno sheet. If theyre sticklers, and you don't have a dyno sheet, they throw you into TTR.
TTU is the same as ST1, so its weight/hp >= 5.5
Old 06-16-2009, 12:34 PM
L98Terror
L98Terror's Avatar
If it's a C6 Zo6 you need a dyno sheet and if it falls into 5.5 :1 than it's TTU, 8.7:1 TTS
Stock C5 Z06 = TTA
Old 06-16-2009, 12:36 PM
davidfarmer
I think I have an old dyno sheet....actually makes LESS power now, so that shouldn't be a problem.
Thanks!
Old 06-16-2009, 12:45 PM
L98Terror
L98Terror's Avatar
Thanks!
A dyno sheet is good for 1 year and is required for TTs & TTU otherwise you get put in TTR
Old 06-16-2009, 12:50 PM
sperkins
sperkins's Avatar
Good luck David.
wallyman424
Actually I just pulled this from the time trials rules:
"Certified Dyno reports are potentially valid for up to a maximum of three years (provided that no changes have been made to the vehicle that would alter Dyno readings). However, at his discretion, a NASA TT Director may require an updated certified Dyno report (at the driver’s/owner’s expense) after one year from the date of the previous report."
I don't think it'll be a big deal, since stock C6z is nowhere near the limit for TTU
To NASA Time Trial Question
Old 06-16-2009, 10:30 PM
ScaryFast
ScaryFast's Avatar
David, a check ride should be waived, but be aware that a comp license doesn't mean you can drive TT. In other words, you'll probably have to spring for a separate TT license. I ran TT last month to shake down a new build, and had to buy an annual TT license even though I already have a valid 2009 comp license.
Perhaps you can get it waived since you're in a different region or for one event, but just a heads up.
Old 06-16-2009, 10:32 PM
wallyman424
really? is it different in the great lakes region? that didnt happen to me in mid-a... strange.
Old 06-16-2009, 10:34 PM
davidfarmer
I'll as Julie if I decide to register. I did TT's a few years ago, and they never made me get a TT license. I've never heard of a group that didn't allow a wheel-to-wheel license to cover TT/Solo etc, but NASA is a money machine after all!
Quick Reply: NASA Time Trial Question
