Which Clutch Are You Using????
Old 06-15-2009, 11:18 PM
NemesisC5
Support Corvetteforum!
NemesisC5's Avatar
Default Which Clutch Are You Using????
It's time to replace the clutch in my 02 C5Z and I would appreciate some input as to what clutches you roadcourse guys are running. I have basically stock LS6 with a few mods the car came with when I purchased it for track duty with 51k on the odometer.
Old 06-15-2009, 11:19 PM
wallyman424
wallyman424's Avatar
no question about it, get the SPEC stage 3 with aluminum flywheel and aluminum pressure plate and don't look back.
its about 1000 all together, and completely worth it.
here's a list of the people I know running this clutch:
me
oyishdog
falcon
jaymz
raftracer
Old 06-15-2009, 11:26 PM
NemesisC5
NemesisC5's Avatar
me
oyishdog
falcon
jaymz
raftracer
Do you use LS6 master cylinder? Where in pedal travel does the SPEC 3 engage?
Old 06-15-2009, 11:30 PM
wallyman424
I homebrewed a tilton MC very similar to the tick performance setup. Danny said his/james/jody's cars didnt need them, but some do. I have no idea why my car needed it, but I had to put it in there. I wasn't getting proper clutch disengagement at high rpms.
Nice thing about my MC is that its adjustable, so I can set it wherever I please.
Old 06-15-2009, 11:37 PM
RAFTRACER
RAFTRACER's Avatar
I think it is a 50/50 chance whether you need it or not....which sucks.
Maybe the newly designed SPEC pressure plate/diaphram spring will eliminate this, they jsut came out with some new wigit, I just haven't installed one yet, and the jury will be out until 10 are installed anyway.
Wally, James' car required one, mine did not...as I said 50/50.... Get you A## registered for Mid-Ohio, or I am bringing a ST2 car to VIR in July
Old 06-15-2009, 11:39 PM
wallyman424
I've gotta wait till the first week of July to see what my schedule's like. I can promise that if I have that weekend off I WILL be there.
That, and I've gotta get this aero nonsense sorted. I'll be giving you a call about the nose soon.
Old 06-15-2009, 11:43 PM
NemesisC5
NemesisC5's Avatar
My car has a SPEC 2/3 that came in it and having the same issue at high rpm's. I may just try the Tick adjustable MC first before I replace clutch. Clutch replacement may can wait till tranny rebuild, its not slipping but rather engages with pedal barely off floorboard???
Old 06-15-2009, 11:44 PM
wallyman424
yes sir, thats what happened with mine. Get yourself that tick (PITA to install BTW, prepare for some serious cursing). Mcleod has a direct replacement unit thats much much easier to install. It will also do the trick. Up to you which you use.
Before I put the tilton in there the clutch was engaging right off of the floor.
Old 06-15-2009, 11:51 PM
RAFTRACER
RAFTRACER's Avatar
The McLeod master cylinder has been unavailable since last year, however they are expecting that they will have stock at the end of THIS month, or at least this is what they told me 2 weeks ago when I had to order a TICK piece ( which is not as easy of an install as they lead you to believe ) The McLeod is much easier.....
Old 06-15-2009, 11:52 PM
wallyman424
I would rather remove the entire drivetrain again than do another tilton install. It gets really claustrophobic under that dash. Plus I almost dislocated my shoulder... twice.
it'd probably be better in an uncaged car FWIW.
Old 06-15-2009, 11:57 PM
RaleighSS
RaleighSS's Avatar
I am using a RAM Clutch Power Grip and the Ram Adjustable Master in mine.... Have had no issues after 25K with it. Motor is right at 440RWHP and she sees 1/4 mile and a number of HPDE runs.... Good setup for the cost.... I think i got 600 in everything ... Master / Slave / Clutch / bleed line.... I "use but don't abuse" and have had 0 issues.... I Replaced my Stock one at 25k Because my master fell to the black sludge due to lack of maintenance ....
Old 06-15-2009, 11:59 PM
NemesisC5
NemesisC5's Avatar
Sounds like I need to check on availability of the McLeod....if not available the Tick goes in.
Thanks guys for the good info
Old 06-16-2009, 12:04 AM
NemesisC5
NemesisC5's Avatar
Originally Posted by RaleighSS
I am using a RAM Clutch Power Grip and the Ram Adjustable Master in mine.... Have had no issues after 25K with it. Motor is right at 440RWHP and she sees 1/4 mile and a number of HPDE runs.... Good setup for the cost.... I think i got 600 in everything ... Master / Slave / Clutch / bleed line.... been 18 months with it now...
$600.....that a lot of goods for that amount of money, especially after 25k miles and still going....
Old 06-16-2009, 01:09 AM
RaleighSS
RaleighSS's Avatar
Yes... I found another member who was running the same combo ... guess its all preference.....
Check out their webpage give um a call they are In SC and were very helpful when i called them with questions before
http://www.ramclutches.com/
Old 06-16-2009, 07:55 AM
Gray Ghost GS
"AlohaC5" Senior Member
Gray Ghost GS's Avatar
I'm using the stock master cylinder with my RPS dual friction clutch - no problems at all while pushing a fair amount of horsepower/torque around the road course. I'll be buying another one when this one eventually wears out - no sign of that though!
Old 06-16-2009, 09:04 AM
tracjunkie914
tracjunkie914's Avatar
anybody running their mini twin?
Old 06-16-2009, 03:47 PM
NemesisC5
NemesisC5's Avatar
Mcleod PN 139000.....placed my order today with Scoggin Dickey Performance.
To Which Clutch Are You Using????
Old 06-16-2009, 04:37 PM
RAFTRACER
RAFTRACER's Avatar
Kewl.......You're going to be miraculously "fixed"
Old 06-16-2009, 05:11 PM
NemesisC5
NemesisC5's Avatar
I could use a few miracles......I may start "speaking in tongues" if this keeps me from granny shifting!
Old 06-16-2009, 09:38 PM
kelp
kelp's Avatar
Fidenza kit dual disc with flywheel. Expensive. Hard to drive for about 1000 miles. But the Clutch fluid stays clear all year.
Quick Reply: Which Clutch Are You Using????
