Tire question...
Tire question...
any problems putting new front rubber on and not the rear if the rears are in good shape? Any handling issues with more up front grip? Would it be better to swap sides with the inside to the outside?
Don't see a problem with that, although youre wear cycles will be offset. As for the tire flip, not if you're running hi-perf street tires; most are unidirectional. I flip my V710's every two track sessions.
