pump loss in oil lines
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
pressure loss in oil lines
Thought you guys might find this interesting, it came up at work with a heavy oil we're using and the gear box we are trying to plumb.
Did you know that your standard 90degree fitting is equal to running 2.5 FEET of line?
something to think about since there's a pressure drop for every inch of line.
The stuff were using is so thick I'm having a 1psi drop for every INCH of line!
http://www.engineeringtoolbox.com/re...gth-d_192.html
http://www.engineeringtoolbox.com/eq...hod-d_804.html
http://www.engineeringtoolbox.com/fr...ds-d_1444.html
If you have that much line loss you need a bigger diameter line and slow it down so that you get the losses under control. If you double the diameter you get 4X the area and the and the velocity is 1/4 of the previous line size. Since the losses go up with a square of velocity, 1/4 the velocity is 1/16 the loss...
Losses go down big time with diameter...
