*** Get Ready for the Track with Brake Upgrades from LG Motorsports ***
Former Vendor
If you plan on heading out to the track this summer, make sure your brakes are up to the task.
Cobalt Friction is an excellent choice when considering track pads for your Corvette. Why pick Cobalt?
Cobalt Friction's XR-Series Carbon-Ceramic friction composites represent a significant advancement in the evolution of motorsports brake pad technology. The XR-Series materials have unparalleled consistency and friction stability over the broadest operating temperature range in the industry (50°F to over 1600°F). Furthermore, unlike traditional resin-based compounds, Cobalt XR-Series friction composites do not require bedding/burnishing to achieve optimal performance, and exhibit consistent performance throughout the life of the pad.
Here's just a sample of what we have in stock at LG:
C5/C6 Front CSR Compound - $269
C5/C6 Rear CSR Compound - $239
C5/C6 Front XR2 Compound - $289
C5/C6 Rear XR2 Compound - $259
C6 Z06 Front XR2 Compound - $429
C6 Z06 Rear XR2 Compound - $329
Along with upgraded pads we also suggest going with StopTech stainless steel brake lines and higher temperature brake fluid.
StopTech Brake Lines for C5 Complete Set - $185
StopTech Brake Lines for C6 Complete Set - $210
Motul RBF 600 Brake Fluid - $24.95 Pint
StopTech also makes upgraded, affordable rotors for use with your stock C5/C6 calipers. These rotors hold up to track use much better than OEM rotors.
StopTech C5/C6 Slotted Rotors - $456.26
StopTech C5/C6 Drilled Rotors - $480.00
And for keeping your brakes cool, don't forget our Spindle Duct cooling kit. This kit will help extend the life of your brakes by keeping temperatures under control when you're at the track.
G2 Complete Spindle Duct Kit for C5 - $439.95
G2 Complete Spindle Duct Kit for C6 - $399.95
(C6 Spindle Duct Kit Pictured)
Call LG Motorsports for all your Corvette needs!
972-429-1963
972-429-1963
