Got a Question about your Corvette? 10,000 Private Messages
Old 06-12-2009, 11:35 AM
0Anthony @ LGMotorsports
Former Vendor
Anthony @ LGMotorsports's Avatar
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Default Got a Question about your Corvette? 10,000 Private Messages
Figured that is as close as I am going to get to 100% full without having reject messages. This is after I deleted a few hundred when they first signed me up on here in!
So feel free, Shoot me a question!
Thanks to everyone on the Forum for your questions, comments, and orders. We wouldn't be where we are today without you guys and gals!!!
Old 06-12-2009, 11:42 AM
Sidney004
Sidney004's Avatar
Now that it does not matter anymore, what were your camber settings, hot pressures and tire temps on the Dunlops?
Old 06-12-2009, 11:56 AM
Former Vendor
You know, alignment settings from the ALMS car to your street car are not going to be direct comparisons, as pick up points are moved, control arm lengths are different, roll centers are different......just not the same geometry.
Old 06-12-2009, 12:32 PM
froggy47
froggy47's Avatar
Thanks Anthony for being available to us "little guys".
How's Boris doing?
Old 06-12-2009, 12:33 PM
froggy47
froggy47's Avatar
Thanks Anthony for being available to us .
How's Boris doing?
Old 06-12-2009, 12:38 PM
Former Vendor
How's Boris doing?
I'm the little guy around here
Boris is doing very well, and I believe has already been in a few other cars. He will be doing some Sprint Cup races this year as well so be on the look out as the man drives everything with wheels!
0Louis @ LG Motorsports
Former Vendor
Louis @ LG Motorsports's Avatar
2.2-2.4 in the front, 1.4-1.6 in the rear. Give the car what it needs, not what my car has Just because it works for me, doesnt make it ideal for you. Use those to start, and tune it from there
Aero, weight, suspension points, uprights, track, track temp all play a very important role in setup, but thats the gist. I would not run that much rear camber on a factory pickup point car, FWIW...
Old 06-12-2009, 12:44 PM
LTC Z06
Get Some!
Support Corvetteforum!
LTC Z06's Avatar
I've helped with that
Old 06-15-2009, 12:41 PM
Former Vendor
Only a little
Old 06-15-2009, 01:16 PM
davidfarmer
davidfarmer's Avatar
that's almost as many messages as I get......I'm closing in on 10years with the forum. Somehow Jody (Falcon) got here before me!
Old 06-15-2009, 11:49 PM
jiggyracing
jiggyracing's Avatar
Default 10,000'th question
here's some specifics:
2005 c6 corvette z-51 fully caged
3260 lb with me in it
stock motor with LG header, air box, exhaust
LG coil overs
front spring 700 lb; rear spring 600 lb
hoosier r6's 335 r18 rear; 295 r18 front
LG camber plates
pfadt adjustable sway bars front and rear
apr wing and splitter
(the dreaded) quaife differential
diff cooler, LG radiator with cooler, lingenfelter extra cooler, accusump, etc.
stock brakes/PFC pads/steel lines/baer rotors
more comfortable for me is: "a perfectly balanced car" - seriously i am more comfortable with a little oversteer that i can control with throttle
here's some questions:
front camber?
rear camber?
tow?
ride height front?
ride height back?
you guys friggen rock.
JIGgy racing
Tucson, AZ
Old 06-16-2009, 01:58 PM
Former Vendor
PM sent
To Got a Question about your Corvette? 10,000 Private Messages
Quick Reply: Got a Question about your Corvette? 10,000 Private Messages
