Oil Starvation in high-G left turns. A thorough investigation.
Dreamin did an excellent writeup in the C6-Z06 Discussion forum. Of course, the C6 Z06's have a dry sump, so the problem would probably be much worse for a non-Z06.
http://forums.corvetteforum.com/c6-z...hard-data.html
You guys need to read all the stuff I went thru developing the LS3 for the track. Man, was that painful!!!!! And yep, turning left is the achilles heel of the LS engines. I'm hoping my new dry sump will solve the problems.
My current LS3 (with the bat-wing pan) is for sale by the way on this forums. Make me a decent offer and it's yours.
OK, I read that post, and here is my question. Please help cure my ignorance.
Let's start with a wet sump explanation to set the stage. If you lack oil in the pickup part of the pan, you do not have oil flow through the pump and hence the lines that dump the oil back into the motor. There is no reservoir that holds extra oil in case the pump is not supplied, so hence you have a moment of low to no oil pressure and what happens next we all know.
But in dry sump, even if the pick up in the pan doesn't have an oil supply for a few moments, the canister from where the oil is pumped back into the motor has a supply of SEVERAL quarts on tap at any given moment. I have heard arguments about some of the oil being "frothy" or "airated" in the canister. But I though the WHOLE point of a dry sump is that an oil starvation issue due to G load does not effect the sump because there is such a large reserve of oil to negate the lack of oil at the pickup for several seconds (let alone a 1/2 second).
So while his oil starvation data is good, wouldn't the fact that there is enough reserve oil in the canaster negate a momentary lack of oil supply in the system?
many of the LS7s oiling issues were not in high speed left sweepers, but under very hard braking.
the Oil was staying UP in the heads and not draining back to the pan or sump.
IIRC is why GM redesigned the dry sump or recommended the LPE or ARE dry sump kits
So..................is an unmodified C5 Z06 (batwing) better or worse than a dry-sump C6 Z06 for track use only.....and will addition of an Accusump ensure the engine lives during track days (RACING on a roadrace track with sticky tires)?
Don't confuse and accusump with a dry sump. An accusump is a pressurized container that holds oil that feeds into the pan/pickup in case of low oil pressure.
A dry sump is a separate container (lots of oil) that has a line feeding directly into the pump...so there's no loss of pressure (in theory). The pan has pick up tubes that collect the oil and return it to the separate container.
The benefit of the dry sump is that there's no oil in the pan that the crank can pass thru (called windage losses).
A C5 LS6 engine is bulletproof. It just doesn't have that extra 100 HP that the C6 does. Unless you're competitive racing against monster engines, the LS6 is a superb engine and will last forever. You don't need an accusump on an LS6...although many people use them. I put over 25K racing miles on 2 LS6 engines with no failures.
"A C5 LS6 engine is bulletproof. the LS6 is a superb engine and will last forever. You don't need an accusump on an LS6...although many people use them. I put over 25K racing miles on 2 LS6 engines with no failures."
Sorry, wasn't trying to insult anyone.
You won't have any issues out of your LS6. Depending on the track, I'd run mine up to 7200 and I've heard of folks setting their limiter at 7500!!!!! It's not good on the valve springs, but they run. I think my normal shift points were 6500-6800 and I had no issues at all.
I'm trying to develop something for the two-piece batwing pans that might give them quite a bit more resistance to starvation.
So if Dreamin has a drysump, which has a large reservoir of oil to supply the engine, then I would think it should not be affected by G load. What was causing his oil pressure drops in long high-G left turns? Did the canister tank run out of oil occasionally, maybe because high Gs exposed the pump pickups in the pan? Or were high Gs pushing the oil in the canister tank away from the pump pickup in the canister? Or a combination of both?
Does an accusump overcome all this by using air pressure to push the oil out of the accumulater tank?
Any idea how often the Accusumps activate on the fastest T1 cars?
By the way, I loaned my old blown shortblock to Ishihara-Johnson Crank Scrapers. They are making a scraper to fit LSx motors. If it works, it should remove oil from the windage cloud and return it to the sump, lower oil temps a bit and give a tiny bump in power. They also thought there were gains to be had with a modified windage tray.
I've got the same question.
anyone with a 2008 LS7 should change their dry sump tank. Again it was not so much the high speed sweepers that our friends at Chevy told us, but under very hard braking the oil was staying up in the heads and not draining back to the pan and tank for pick up.
They even recommended the LPE tank as it was less expensive the the Chevy replacement tank.
For us non-Z06 LS3 folks, is adding an Accusump a suitable fix for this problem (assume no class rules to contend with)? Do folks feel the bat wing pan alone is enough?
What I don't understand is why GM would bother with such a terrible dry sump system. > 1.0 gee for 4 seconds isn't much, and there as wet-sump systems which work flawlessly in road racing competion (e.g., the gen 4 Viper's swinging pickup).
Dreamin's results clearly show starvation in left-hand turns, though I don't know how hard he was braking.
at the NCM Road America HPDE least year, two instructors blew LS7s. Both engines were replaced at BG.
Is this concluding that the 'redesigned' OEM dry sump system on the '09's is not worth BEANS as well?
I believe it has a 10.5 quart capacity - right?
Reason I ask is - I'm considering the purchase of a 2010 Grand Sport (LS3) manual coupe, which has the Z06 dry sump. I will be very disappointed if it's not any better for track use then a wet sump LS3 - that was the whole point ...
I've followed your past posts on this issue with great interest, including GM's high $ bat wing pan offering.
Personally, I don't think the accusumps can act quickly enough...and are generally speaking a waste of time, money and weight. Neither of my LS6 engines had an accusump and I had no issues. Others who ran the sumps, had problems. I won't use one.
The bat-pan on mine seems to work pretty well. I'm not sure what they changed from my prototype to the actual production version, but I don't think they are the same. The DRY sump is definitely the way to go though with the LS3 engine.
And, the LS3 is just fine with stock suspension, tires, etc. It was designed to handle up to 1.2 Gs (spikes) and I think the GM guys said 1.1 sustained Gs with no issues. But, when you add racing tires, suspension and sustained Gs of 1.6-1.9, you'll need either the bat-wing pan or a dry sump. And right hand turns aren't the issue either...just when turning left.
I would not run an LS3 on track without at least the bat-wing pan. Again, my LS3 with the bat-wing is still for sale if anyone is interested.
Oh we can run an accusump... but Mike Tracy was running both his accusump and the bat-wing pan at the runoffs at heartland park and we all saw what happened. My car was the ONLY LS3 to complete the weekend. I started the race with 2 quarts over, but looking at the data, by lap 14, the pressure vs. rpms were getting dicey. Co-incidentally, that's when Tracy blew his up.
