First AX in the Z - quick question
Hello everyone,
I participated in my first autocross in the new to me '04 Z06 this past weekend. It was an awesome, two-day airport event - very fast courses!
I cannot believe how strong these cars are bone stock. It does everything well. I previously ran a modified 1997 Cobra and thought it was a good autocrosser - worlds apart. Did pretty well to. Here's a link to the results. I'm number 3 in SS.
http://www.swvrscca.org/vb/showthread.php?t=1774
I do have a question I hope you all can help me with. During the event, on both days, I got intermittant "service active handling" messages. I've already done a search on this and found the persistant grounding issues. I'll check those the next chance I get but, to be honest, my scenario doesn't seem to fit. Specifically, I only got the messages when the car was very hot - 225 degrees or so coolant temps at the end of the run. When I did a better job keeping the temps down between runs and the temps were not as high at the end, no messages. No issues or messages at any other times on the street (before or since) either. Has this happened to anyone else? Should I be concerned? While I run autocrosses with the system off, I do want it functioning properly on the street.
Thanks in advance!
Jerry
Thanks in advance!
Jerry
Hello everyone,
Thanks in advance!
Jerry
Thanks in advance!
Jerry
You are getting the code because the voltage is dropping below the require 5 volts. I've done 6 years of autocrosssing, including 4 nationals, 6 Prosolos and many National Tours.
I experienced this is roadracing and found the heat source was the headers heat causing the ground junction in the Starter to crack apart.
This cause an intermittent ground fault. Having an active handling unit going off and on can cause, in my case, front brakes lock up at FIR.
No good! Track it down with an expert. Put a heatshield around the starter and wrap all the O2 sensor wiring too.
Thanks guys, sounds like I will have to start checking grounds. Anyone have instructions on pulling codes from the DIC handy? When I try to log into the tech tips pages, I keep getting a "page cannot be found" error.
Thanks for the answers!
