FS: 2007 C6 prepped race car - DAMAGED - Needs front clip
1 Post
Car was on road for a short time and then completely gutted and pulled apart for full time track car in SU class....car had less than 50 laps on it when it went into a wall (see pics for details)....has been converted to Z06 body....missing brakes (front and rear) but have a full set of C6 Z06 brakes for sale if interested...car will be sold as is, asking $9,000 and includes all parts in pics....title in hand
Engine:
427 LS7 - built by Scoggin Dickey Engines - 560RWHP (470RWTQ)
3 stage Aviaid dry sump system (damaged-see pics)
**Has not been inspected yet**
Transmission:
T56 RPM Stage 4
Differential:
DTE Stage 4
Wayne
w m c k e e n s t e r @ g m a i l . c o m
see pics here:
http://s557.photobucket.com/albums/s...%20race%20car/
Engine:
Transmission:
T56 RPM Stage 4
Differential:
DTE Stage 4
Wayne
see pics here:
Have you checked any of the drive train yet for damage?
1 Post
Thanks to the cage we believe the drive train is okay as the rear part of the frame seems to be okay and the doors still open perfectly....
however, we have not taken anything out yet to inspect which is why we are advertising as is....we do know that the 3 stage dry sump pump will need to be repaired and obviously will need a new tank...the trans, diff and motor alone are worth it but if we pull the car apart to inspect drive train we will be selling entire car pieced out....
I have the build sheet for the LS7 motor at $26K from Scoogin Dickey in Texas....the DTE stage 4 diff is $2400 and RPM stage 4 trans is $2000 (NOT including cores)....
any other questions please do not hesitate to ask
