305/30/18 square setup OK for tracking C6Z?
My buddy has access to some Toyo R888 305/30/18 scrubs and I was wondering if that would be an OK setup to run square on 4 C5Z rears on my C6Z. Im hoping it keeps it neutral but am not certain. Also its always nice to be able to rotate those bad boys
I wasnt sure if that OD was too small. Also, I've heard conflicting information regarding the traction control and abs.
If thats no good, is there any advance to...
275/35/18
335/30/18
275/35/18
335/30/18
as long as the rims are not too wide for the tire the 305 will be fine. many people have run the 18 inch z06 all the way around. it all depends on how much money you are willing to plunk down on rims.
18 rear z06 all the way around IMHO is a good way to get a taste of sticky tires for minimal cost on your car
I've run all sorts of scrubs, from 285 - 315 in various diameters. As long as you run TPM's, you probably won't have any issues. I run with AH/TC shut completely off, and haven't had any issues even without sensors.
Where's a good place to pick up a set of those enexpensively?
Most everyone is running 12 or 13" rims on 325/335/345 tires in the rear!
