what model chatterbox??
Old 05-30-2009, 07:24 PM
dvandentop
dvandentop's Avatar
Default what model chatterbox??
what model chatter box does everyone use ??
dean had a good one at track attack
thanks
Old 05-30-2009, 08:04 PM
FredSM
FredSM's Avatar
I use the CB-50 Tandem Pro. Mounted my headset semi-permanently in my helmet with a shortened cable to the unit which is clipped to my helmet. Don't like the DIN-style connectors. They occasionally pop out just as I'm about to impart some incredible wisdom on a student.
FM
Old 06-03-2009, 09:49 PM
RusherRacing
RusherRacing's Avatar
I don't use a chatter box but a NADA works great and cheap
Old 06-03-2009, 09:59 PM
dvandentop
dvandentop's Avatar
got a link?
Old 06-04-2009, 12:12 AM
allanlaw
allanlaw's Avatar
thanks
HJC-50. Used it for years and it always works great (more than I can say for most of my racing junk) . . .
Old 06-04-2009, 01:35 AM
Joy of 6
Joy of 6's Avatar
Here is what I use. good clear communication. think it is the same one Dean uses. You can pick out what kind of mic and headset to fit your needs. I use the full face and it is mounted inside my helmet. Was kind of messy cutting out the foam to make it fit.
http://www.motorcycle-superstore.com...cator-Kit.aspx
Old 06-04-2009, 06:40 AM
AU N EGL
AU N EGL's Avatar
HJC-50 and two open face helmet boom mics
Old 06-04-2009, 07:04 AM
JDIllon
JDIllon's Avatar
I use the Chatter box mounted in my helmet for me and a seperate boom type mike for the student. I started out with the portable mikes for me and the student, but putting the mike in and out on mine became a real pain. JD
Old 06-04-2009, 04:24 PM
ErnieN85
ErnieN85's Avatar
much nicer
Old 06-04-2009, 05:36 PM
vms4evr
vms4evr's Avatar
HJC-50 with Student mike(s). Extension cord on 1 mike. with recharger. got it all in a kit a couple of years ago. works very well in full or open face helmets.
Old 06-04-2009, 08:23 PM
Poor-sha
Track Rat
Support Corvetteforum!
Poor-sha's Avatar
Received 3,400 Likes on 1,372 Posts
+1 I permanently mounted a headset in my helmet and bring along an extension cord. Since most instructors are using Chatterbox I just plug in to their unit rather than deal with the removable boom mics (which every instructor would hand to me with a warning about not pulling on the wires).
Old 06-04-2009, 11:06 PM
kmagvette
kmagvette's Avatar
HJC-50 Tandem here. I use the portable mics, student gets an extension cord. I do not find them to be an issue to use. Perm mount in my helmet would be nice especially if I could recess the ear piece into the helmet a bit to relieve pressure on the ear. Multiple students days can get a little uncomfortable with the ear piece embedded in your ear. Apparently not bad enough to motivate me to work on it.
Old 06-04-2009, 11:16 PM
dvandentop
dvandentop's Avatar
can you use 2 of these then with an extension for the passenger one?
Old 06-05-2009, 01:51 AM
Joy of 6
Joy of 6's Avatar
Forgot to mention. If you get this one be sure to zip tie the cord to the boom because when the student grabs the electrical cord and pulls it out of his helmet the cord will come out of the ear piece
Old 06-06-2009, 03:48 PM
kmagvette
kmagvette's Avatar
This is exactly what I use. Zip tie the foam piece on as well. I have never knocked mine off but students seem very adept at it. I have found theirs on their seat, the back seat, and, under the driver's seat - then I zip tied it.
To what model chatterbox??
Quick Reply: what model chatterbox??
