Race Seats
Old 05-21-2009, 06:17 PM
mrc562
Support Corvetteforum!
mrc562's Avatar
Default Race Seats
I'm looking for a seat that fits in a 2006 Z51 coupe. The upper harness strap slots have to be at least 30 in. up from the seat bottom I have had no luck with corbeu. is there a seat out there that fits in the C6 and is for a tall driver.
Old 05-21-2009, 08:00 PM
02impactblue
02impactblue's Avatar
The A4 didn't work?
Old 05-21-2009, 09:56 PM
Silverton
Silverton's Avatar
I have a beautiful Racetech 4009WT (W = wide, T = tall) for sale. I bought it to put in my '07 Z51 put never got around to it. This seat is new and never been used. It was a special order, as Racetech only carries the 4009W. I paid $1450 for it, and will sell it for $1000 shipped to lower 48.
I'm 6' 4 1/2" and the shoulder harness cutouts fit perfectly.
I also have a Hardbar seat rail setup for this seat, also for sale.
PM if interested.
Here's a link to a regular size Racetech 4009 seat: http://www.motorsportimage.com/pc-40...race-seat.aspx
A very comfortable seat.
Old 05-22-2009, 09:16 AM
mrc562
mrc562's Avatar
Hey Rob
No the A4 cut outs are to low. I saw that you were asking about the 18 D-RR Kirkey they look good. What do you think about them?
Old 05-22-2009, 01:33 PM
0JoshS
Former Vendor
JoshS's Avatar
St. Jude Donor '08
Autocross & Roadrace Forum Sponsor
I have had really great luck with the Sparco Evo series of seats. The Evo and Evo 2 fit very nicely. I have received mixed results from the Evo 2 Plus for fitment. It seems that some have no problems and others have to do some trimming.
Here is the seat dimension guide for Sparco seats:
http://www.sparcousa.com/resourceFiles/26.pdf
Old 05-25-2009, 10:14 AM
mrc562
mrc562's Avatar
Thanks for the info. I will look at the Evo's
Old 05-25-2009, 01:07 PM
02impactblue
The Evo's harness holes are too low. You sat in those at Summit Point. I think you need to look at the Kirkey 18"
Old 05-25-2009, 01:24 PM
Bill Dearborn
Bill Dearborn's Avatar
Received 8,928 Likes on 5,333 Posts
Or an Ultrashield. With an aluminum seat you can cut the harness holes larger and customize it to fit you. You can also get a custom seat from both of these manufacturers. You are not stuck with what the manufacturer has in stock.
Bill
Old 05-25-2009, 01:43 PM
mrc562
mrc562's Avatar
Rob I was thinking about trying to go down to OG on Tue. Do you have time to go?
Old 05-25-2009, 02:20 PM
rustyguns
rustyguns's Avatar
Kirkey !!!!!!!!!!!!!
Old 05-25-2009, 04:30 PM
GettReal
GettReal's Avatar
Default Corbeau FX1 Pro
I looked at recaro, sparco and Corbeau seats... I took a ton of measurements on so many of these seats because I had to be concerned about my fitting it in with my existing 6pt roll bar. I found almost all the slots for harnesses were about 24" off the top of the seat. I'm a tad over 6'1 and mine line up fine. I dont know where the kirkey slots are but 30" is really high up.
I just took the padded seatbottom out to measure and its now 26 1/2" to the slots.
Old 05-25-2009, 10:19 PM
mrc562
mrc562's Avatar
Thanks GettReal for the info> I'm about 6'3 more torso than legs I need for the slots to be at least 30" from the seat.Im going to OG Racing to try the Kirkey D-RR 18
Old 05-26-2009, 03:16 PM
mrc562
mrc562's Avatar
Thanks to everyone who gave info. Iwent to OG Racing and got the Kirkey 18 D-RR and it fits great. Thanks agian!!! Russ
Old 05-26-2009, 08:40 PM
rustyguns
rustyguns's Avatar
luv my kirkey
Old 05-26-2009, 10:51 PM
Silverton
Silverton's Avatar
Um, the Racetech tall seats have appropriately positioned seat belt pass-throughs. The Ractech 4009WT is similar to Kirkey seats except it is made of fiberglass.
To Race Seats
Quick Reply: Race Seats
