Does your Master Cylinder cap leak?
Old 05-21-2009, 02:41 PM
cj68
cj68's Avatar
Default Does your Master Cylinder cap leak?
I find that I have to wipe up brake fluid off of the area around the master cylinder resevoir after every session. I do not over fill my m/c and I put on a new cap, but it still sprays some fluid out of the fill cap.
Are there any tricks to tighten down the cap? I have heard of people rubber banding a rag around the cap, but to me that is a fire risk.
Thoughts or solutions?
cj
Old 05-21-2009, 03:38 PM
AU N EGL
AU N EGL's Avatar
Only fill the MC 1/2 way beteen the center seam and the FULL line.
Do not fill to the FULL line.
Hot brake fluid expands
also zip tie a small rag around the MC cap to absorb any spilled brake fluid
VetteDrmr
VetteDrmr's Avatar
Received 1,394 Likes on 747 Posts
The MC cap is vented, so you need to make sure the fluid level is down towards mid-level.
Have a good one,
Mike
Old 05-21-2009, 04:02 PM
cj68
cj68's Avatar
yep, I do that and it still spays. I will try the ziptie and rag approach.
cj
Old 05-21-2009, 04:03 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
buy a new cap, it shouldn't leak if you aren't overfilling
Old 05-21-2009, 04:20 PM
cj68
cj68's Avatar
I did that too and it didn't leak for a few track days, but now it is leaking again. Maybe I need to buy a few new gaskets and change them out a couple times a year.
Thanks,
cj
Old 05-21-2009, 04:28 PM
Aardwolf
Aardwolf's Avatar
Are you sure it's not spraying out of the back of the M/C? That'd be bad seals in the M/C for my year.
Old 05-21-2009, 05:38 PM
froggy47
froggy47's Avatar
I think this falls into they all (or most) do. Mine does. I just wipe it.
My p/s cap does the same.
Old 05-21-2009, 06:12 PM
Kanmer
Kanmer's Avatar
Cruise-In VI Veteran
I took a Mobil 1 quart bottle and cut the front off. Cut a piece the shape of the m/c cap out of the platic from the bottle. It must just fit inside the cap. Place it between the cap and gasket. It works like a shim. It isn't overly tight but provides an little more force on the cap.
Try it, it just might work for you.
Bob
cor66vette (04-20-2017)
Old 05-21-2009, 06:42 PM
ZR1 MK
ZR1 MK's Avatar
I installed a second gasket on the cap made from gasket sheet for a tight fit.
I recommend proper brake fluid level.
Old 05-22-2009, 09:56 AM
cj68
cj68's Avatar
Thanks for the suggestions. I will try and shim the cap.
Chris
Old 04-20-2017, 01:57 PM
cor66vette
cor66vette's Avatar
Received 1,308 Likes on 690 Posts
C3 of Year Finalist (stock) 2019
C2 of Year Finalist (stock) 2019
Bob
I'm having a similar issue on my '75. I like your suggestion.
I cut out an oil jug into a gasket, put it in, and the cap feels tighter already. I'll know if it works after my next drive. Fingers crossed.
Old 04-21-2017, 11:57 AM
cor66vette
cor66vette's Avatar
... aaaaaaaaand, it worked!
To Does your Master Cylinder cap leak?
Quick Reply: Does your Master Cylinder cap leak?
