FS Penske 5200 dbl adjustable shocks c6/z06
Old 05-18-2009, 10:52 AM
jstout
jstout's Avatar
Chattanooga Area Events Coordinator
Default FS Penske 5200 dbl adjustable shocks c6/z06
Complete set of 4 Penske 5200 double adjustable coilover shocks for c6/z06 with mounting brackets and blocks. Purchased from forum member who indicated only on his car for 2 months before selling car. Condition seems to verify. Never installed on my car. Seperate adjustablility for compression and rebound. Dyno sheets on shocks
available. $3500 plus shipping. THanks. Jerry
Old 05-18-2009, 11:39 AM
GrantB
GrantB's Avatar
Both bump and rebound are on the reservoir, correct? How do they compare to the coilovers Hardbar sells?
Old 05-18-2009, 12:01 PM
wallyman424
wallyman424's Avatar
just from the pictures, they are the ones hardbar sells.
Old 05-18-2009, 08:10 PM
jstout
jstout's Avatar
From what I was told, Gary at Hardbar built these and set them up. I think a new set of 5200's gets close to $4500 or better. As you can see, you can't buy used and get any newer than these. Thanks. Jerry
Old 05-18-2009, 10:49 PM
GrantB
GrantB's Avatar
Do you know what the spring rates are?
Old 05-18-2009, 11:03 PM
gkmccready
gkmccready's Avatar
Bump on the cans, rebound through the lower clevis in the rear, and through a window in the eyelet on the fronts. Same as my 8100s.
Old 05-19-2009, 03:54 PM
jstout
jstout's Avatar
Ttt
Old 05-19-2009, 10:12 PM
jstout
jstout's Avatar
ttt
Old 05-23-2009, 03:24 PM
jstout
jstout's Avatar
ttt
Old 05-26-2009, 10:51 PM
GrantB
GrantB's Avatar
So how do they compare to the 8100s gkmccready is selling? What are their spring rates?
Do you know what they weigh?
To FS Penske 5200 dbl adjustable shocks c6/z06
Quick Reply: FS Penske 5200 dbl adjustable shocks c6/z06
