2011 Camaro Brakes
Old 03-10-2009, 12:04 PM
gkmccready
gkmccready's Avatar
Default 2011 Camaro Brakes
Type: four-wheel disc w/ABS; ventilated front and rear rotors;
single-piston front calipers and single-piston alloy rear cali-
pers (LS, LT); four-piston fixed Brembo aluminum front and
rear calipers (SS)
Rotor diameter, front (in/mm):
LS, LT: 12.64/321
SS: 14/355
Rotor diameter, rear (in/mm):
LS, LT: 12.4/315
SS: 14.4/365
Rotor thickness, front (in/mm):
LS, LT: 1.18/30
SS: 1.26/32
Rotor thickness, rear (in/mm):
LS, LT: 0.9/23
SS: 1.1/28
Anybody know how the calipers mount and if they're volume friendly to Corvettes? I wonder if this means Corvettes will finally get to move away from PBRs? I wonder if we can assume they messed up between the single-piston front and six-piston rear on the non-SS models. :-)
Quick Reply: 2011 Camaro Brakes
