Carbotech XP8
Old 03-09-2009, 02:28 PM
Wingrider
Wingrider's Avatar
Default Carbotech XP8
How noisy are the XP8 brake pads if I want to use them for occasiional HPDEs and daily driver? I can live with brake dust. Thanks.
Old 03-09-2009, 02:37 PM
magnetic1
magnetic1's Avatar
They will make noise everytime you hit the brakes.... but you can use them for street and HPDE. Ive had many customers do this...
Old 03-09-2009, 02:59 PM
Aardwolf
Aardwolf's Avatar
I get some squealing with them and do use them street/track.
Old 03-09-2009, 03:26 PM
95jersey
95jersey's Avatar
I have used XP8's in the rear and race pads in the front. I would just switch out the fronts pads and leave the XP8's in on the street in the rear. When they are in the rear, they make little to no noise, but they will make noise in the front.
Old 03-09-2009, 04:28 PM
EvilBoffin
EvilBoffin's Avatar
St. Jude Donor '09
Originally Posted by magnetic1
They will make noise everytime you hit the brakes.... but you can use them for street and HPDE...
They squeal badly . I like them just fine for street use otherwise.
I just pulled mine off this weekend, cleaned the backing plates and spread some 'Squeal Silencer' goo on them. We'll see if that helps at all...
Old 03-09-2009, 04:56 PM
longdaddy
longdaddy's Avatar
the squealing is not too bad compared to some other pads I have used.
Old 03-09-2009, 06:56 PM
tmak26b
tmak26b's Avatar
They will make noise, just a matter of time.
Old 03-09-2009, 07:33 PM
sperkins
sperkins's Avatar
I guess I'm lucky - my Carbotechs are very quiet.
Old 03-09-2009, 07:47 PM
sothpaw2
sothpaw2's Avatar
Does anyone think the XP8 stops better than a Hawk HP+ ?
Thinking of trying XP8 front & stock C5Z rear. Would that mess up the braking bias too badly??
Old 03-09-2009, 08:35 PM
Aardwolf
Aardwolf's Avatar
They will handle heat better. I put some XP8's through hell at Road America and they never faded. I was very pleased!
Old 03-09-2009, 08:40 PM
magnetic1
magnetic1's Avatar
A whole lot better. The HP+ are somewhere inbetween the Bobcats and AX6.
Id say a HT10 is close to XP8.
Old 03-10-2009, 08:33 PM
USA1C5
Support Corvetteforum!
USA1C5's Avatar
I've been running the XP8's on my C6Z06 front and rear. I put them on for a HPDE at VIR last November and left them on since. They are fairly noisey on the street but the dust is close to the same as OEM. I've got some Carbotech Bobcat's to put on for the street but just havn't got around to swaping them out yet. When the noise gets to be too much to put up with anymore I guess I'll put the Bobcat's in. The noise so far is tolerable.
Old 03-10-2009, 10:18 PM
nhpln
nhpln's Avatar
Do you put any anti-squeal compound on the back of the pads?
Old 03-10-2009, 10:26 PM
USA1C5
USA1C5's Avatar
No I havn't tried that. They are fairly noisey though. I'm thinking about putting the Bobcats on. I already have them just havn't got around to putting them on yet. The noise is tolerable so far but I am starting to get tired of it.
Old 03-11-2009, 12:54 PM
zcobra1
zcobra1's Avatar
Squeal and squeek like a stuck pig on the street....
Specially my rears. Dust more than the stock Z pads - but stock dust a lot also- Carbotech dust seems to wash off easier though...
On the track they are better than the stock GM Z06 pads-
but for me not that much better ......and my front XP10's are almost gone after 6 track days-- rotors still good though and they were new with the Carbo pads. Frankly for almost twice the cost- I am sticking with the stock Z pads...
I ran XP10's front / XP8's rear- on a 2004 Z-
To Carbotech XP8
Quick Reply: Carbotech XP8
