Brake rotor hone
1 Post
Cruise-In II Veteran
Brake rotor hone
Has anyone tried these? It is just like a ball hone for cylinders but for rotors, just to get the crud off of them, especially with transfer pads like PFC's.
http://www.brushresearch.com/pdf/Full20CatalogNo19.pdf
go to page 11
go to page 11
How do you think these will work with getting the pad deposits off the rotors? Also, do you think this would work to remove deposits that cause brake pulsation (don't have much expectation in this area).
Or are these really just to put a non-directional pattern on an turned rotor?
Have a good one,
Mike
Have a good one,
Mike
Dog
Location: If you don't weigh in you don't wrestle Road America
Have a good one,
Mike
Have a good one,
Mike
Joel
1 Post
I have used the Scotch brite as well, but I am looking for something that will work at the track if necessary with a cordless drill. When I am at the shop, I put the rotor in my giant old (1967) LeBlond lathe and the angle die grinder with the Scotch brite works well. This thing is cheap, and I at least want to try it with the Milwaukee cordless dril. BTW, I got this old, but perfect lathe for cheap, because it was being replaced by a CNC lathe. It is huge, (like 2000 pounds) had a quick change tool holder with lots of carbide and ceramic tools in about a dozen tool holders, 3 chucks, 2 faceplates, taper attachment, quick change all-gear drive, coolant setup, etc. You can get these old, but perfect machine tools cheap because everybody wants CNC stuff.
Isn't this hone or cleaning process recommended when ever you change brake pad compounds? I just swapped the OEM pads for Hawks on my Z06, so should I do something like this?
What is the Scotch brite? I know the small scrubbing square but sounds like you are using something on a rotary tool?
