Have you seen this racecar project
Old 03-02-2009, 12:30 PM
BrianCunningham
BrianCunningham's Avatar
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
Default Have you seen this racecar project
for Speedweek
Originally Posted by Daves obsession
this is the orginal rear section
it would not suport a parachute pull.
This is what we did about it.
all ties back to the cage
for the seat mount
I have 16 sec to get out, I think can do it
Old 03-02-2009, 12:51 PM
MySR71
MySR71's Avatar
I'm surprised to see the main roll hoop being connected a plate around the rear bumper. If that is indeed the case, seems like an impact at the rear would be transmit quite a load to the roll hoop and alleviate some of the crumple zone. Maybe I am misinterpreting the pictures.
Old 03-02-2009, 03:59 PM
ScaryFast
ScaryFast's Avatar
I like that cross bar behind / below the seats. I see no point in the curvy bar along the tunnel, unless it's the seat attachment.
Dan I'm with you, it will protect the fuel cell but really trasfer those forces to the driver.
16 seconds to get out? NASA only allows 10...
Brian is this a forum member? He should get the lightweight roof panel from Melrose. Much thinner than the stock roof.
Old 03-02-2009, 04:12 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
Salt flat car???
Old 03-02-2009, 04:13 PM
BrianCunningham
he's a forum member, click on the to go to the original thread.
Old 03-02-2009, 04:32 PM
ScaryFast
ScaryFast's Avatar
Yeah just figured that out. I guess he's not too worried about rear impact at 230 mph!
Old 03-02-2009, 11:43 PM
Daves obsession
Daves obsession's Avatar
Yes its a salt flat car, the rear end is to mount the parachute to .
I was afraid that repeated chute deployements over 220 would deform the original rear. and sence weight is not and issue, its beefy.
the curvey things are the seat base mounts.
Old 05-13-2009, 08:51 AM
BrianCunningham
His cars done
will run it at the texas mile if I don't ball it up at the salt
these are the entry form pictures, has the wrong, tires, ride height, due to the engine being out. it will sit 4.5 inchs lower, when its all said and done.
Old 05-13-2009, 09:24 AM
Cobra4B
Cobra4B's Avatar
CI 3-5-6-7-8 Veteran
I've heard C4s make the best texas mile (high speed) cars because they're longer and narrower than a C5 or C6.
Old 01-18-2010, 10:30 AM
BrianCunningham
His car is done
Old 01-18-2010, 05:17 PM
Bink
Bink's Avatar
Cruise-In V Veteran
St. Jude Donor '09
His car is done
Very cool! Thanks for posting.
Old 07-09-2010, 06:50 AM
BrianCunningham
update for 2010
Well, its 30 days till speed week, and the motor is now ready for install All of Coreys hard work paid off with a significant HP gain.
Old 07-11-2010, 11:39 PM
BrianCunningham
223mph on the salt
Old 07-12-2010, 06:22 AM
rfn026
rfn026's Avatar
I like it. I like it a lot.
Richard Newton
My Speed TV Blog
To Have you seen this racecar project
Quick Reply: Have you seen this racecar project
