Anyone want the ARE Level 3 kit?
Anyone interested in the Stage 3 ARE kit with all Ultralite hoses and AN Fittings? I'll let it go for $2500 + someones stock system..
Does the stage 3 use an external pressure stage pump, or a 3 stage scavenge pump with stock internal pressure pump. Also does it have the tall narrow Z06 style tank or the short fat tank.
Mike
Mike
Its a bigger tank then the stock z06 one, but not a short fat one. It fits in the same location as the stock tank with some slight modifications. It uses the stock internal pump for pressure, but has an extra pump for the a second pickup on the pan. That pump attaches to the A/C bracket, but retains all use of the factory A/C.
thanks, sounds like it is the LS7 system that uses the internal pump for scavenge. I am in need of the LS1/LS6 system with a 3 stage external scavenge pump, and use the stock internal pressure pump.
