NASA TT at Road Atlanta in March
Old 02-23-2009, 05:11 PM
varkwso
varkwso's Avatar
Default NASA TT at Road Atlanta in March
Looks like there are only 5 spots left in Time Trial at Road Atlanta next month already. Instructor is already closed out. I am hoping the tornadoes stay home this year.
Who is going to make the event?
Old 02-23-2009, 06:04 PM
Timz06
Timz06's Avatar
Is that time 'trail' as you will be trailing behind me ?
Old 02-23-2009, 06:08 PM
Falcon
Falcon's Avatar
Hopefully my ABS problem will be solved by then and I'll be there rassin!
Old 02-23-2009, 06:09 PM
varkwso
varkwso's Avatar
I want to see you demonstrating some of those wicked PCA instructor skills...
Old 02-23-2009, 06:10 PM
varkwso
varkwso's Avatar
Jake will be out there in the Stang....
Old 02-23-2009, 08:56 PM
Timz06
Timz06's Avatar
Like red flag drills...
I don't have ABS!
Old 02-23-2009, 09:05 PM
sperkins
sperkins's Avatar
Hey Jeff I'm in for my usual spot. See you guys there.
Old 02-23-2009, 09:52 PM
drivinhard
Support Corvetteforum!
drivinhard's Avatar
still debating, although I'll get killed on my (current) HPDE rubber (555R2's) vs A6 or V710's
guess I should decide...
Old 02-24-2009, 06:49 AM
varkwso
varkwso's Avatar
If we run TTA this event (jury still out on the FRC motor) we will be on one event RA1s - I expect to get smoked but the CMC car needs new tires much worse.
Old 02-24-2009, 12:41 PM
sperkins
sperkins's Avatar
Originally Posted by varkwso
jury still out on the FRC motor.
What if any was the diagnosis and have you figured out a way to blame Jake for it?
Old 02-24-2009, 12:46 PM
varkwso
varkwso's Avatar
I can ALWAYS blame Jake - failing that I will blame my wife....when I come out of my coma the problem will no longer be relevant.
I think it may be a lifter making the noise - it is intermittent now and quiet when warmed up. Of course bearings have been known to do that also...
Old 02-24-2009, 02:10 PM
racerwannabe
racerwannabe's Avatar
St. Jude Donor '06
i have spare blown up engines if ya need one....
planning to work on sunday,,,
Johnny
Old 02-24-2009, 02:20 PM
jaa1992
jaa1992's Avatar
Location: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps GA
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
I gotta find you guys. None of the "On the hill gang" that I hang out with is comming from VA.
I need to figure out if its worth it to try this TT stuff with my stock 92.
I'll be there Friday for the instructor clinic, gonna figure out if that is something I want to do as well.
Old 02-24-2009, 04:54 PM
varkwso
varkwso's Avatar
with any tire at all you will be in TTB with a base class of TTC*.
Look us up we will be clustered around an area with power plugs....
Old 02-24-2009, 10:12 PM
jaa1992
jaa1992's Avatar
St. Jude Donor '12
Well I have 3 choices for tires:
Stock 275 sumito on 17x9.5 rims (stock street)
275/315 front rear V700
315 on 17x11 old v710's
I'll search you guys out on Friday cause I'll need to change from the streets to the v710 set. Got to wear them out before I can buy a new set
Old 02-24-2009, 10:58 PM
vette6aut0x
vette6aut0x's Avatar
Team Leonard will be there plus I will be racing too.
Old 02-25-2009, 07:23 AM
varkwso
varkwso's Avatar
The split paddock and grid makes it tough for Teams both TTing and W2W racing at Road Atlanta. My guess Jake will just have to make the long drive to the pro side every time since I will be on grid so much for TT.
To NASA TT at Road Atlanta in March
Old 02-25-2009, 10:16 AM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
I don't have ABS!
That's just what I want to think about when you're behind me coming into 10a.
Old 02-25-2009, 10:36 AM
Z06Fix
Z06Fix's Avatar
Hope the weather is better this year for you guys. I will think about ya while I'm running around cones in south GA
Old 02-25-2009, 11:58 AM
sperkins
sperkins's Avatar
ok that's not funny.
Quick Reply: NASA TT at Road Atlanta in March
