18 inch track wheels for C5Z06
What is the hot setup for the C5 Z06 in an 18 inch rim at all 4 corners?
18x10 F ?
18x11 R ?
Looking to run a 275 in the front and and a 315 rear.
thanks
18x10 F ?
18x11 R ?
thanks
18x10.5 all around works well
I've used R888 295-30/18 F and 315-30/18 rear with stock rear Speedlines and that works well at the track on an oterwise stock C5Z. In autocross I think 315 all around would work better.
Mike
Mike
Very very expensive to beat four stock rear wheels for the C5Z. The stock ones are pretty light, and inexpensive. To get better than this, you would be buying some custom ones from CCW or Kodiak or something.
How much are the speedlines?
thanks
The c5 coupe/vert is 17x8.5 and 18x9.5 in the rear.
House of wheels sells the gm speedline wheels. They are a vendor here. I checked the websit but did not see any prices. If you check the parts for sale there is always z06 rears for sale or post a wtb thread and you will probably have a set fairly quick.
