WTB: Rear Adjustable T1 Sway Bar
Old 02-18-2009, 06:35 PM
JRL
JRL's Avatar
Default WTB: Rear Adjustable T1 Sway Bar
Looking for a rear adjustable T1 bar
Just the bar, don't need links or bushings.
Thanks,
JRL
Old 02-18-2009, 06:36 PM
ryan0
ryan0's Avatar
Thanks,
JRL
T1 isnt adjustable. Just one hole.
Old 02-18-2009, 06:43 PM
JRL
JRL's Avatar
I'm pretty sure there's a newer bar with 3 holes, one if my buddies has it on his car.
JRL
Old 02-18-2009, 06:48 PM
MattW_VA
MattW_VA's Avatar
St. Jude Donor '07
JRL
J
I have one for sale, but it's the early version without the appropriate bends to accommodate mufflers.. PM me if you're interested.
Old 02-18-2009, 11:26 PM
Lancer033
Lancer033's Avatar
The C6 T-1 bars are adjustable and they will work on a C5, here's my car....sorry, not for sale
Old 02-19-2009, 09:15 AM
JRL
JRL's Avatar
Lancer,
Thanks, thats good info. So I assume that C6 bar has the same stiffness as the C5 T1 bar?
JRL
Old 02-19-2009, 09:31 AM
Wicked Weasel
Wicked Weasel's Avatar
St. Jude Donor '05-'08
Lancer,
JRL
Just note there was a batch of t1 bars made that do not fit the c5 and only the c6.
Old 02-19-2009, 10:20 AM
redtopz
redtopz's Avatar
I bought these bars from a C6 owner for my c5z and they fit like stock.
Lancer,
JRL
I always assumed they did, but I'm not sure. Anyone have the specs? EDIT: Now that I think about it, pfadt racing shows the specs of these bars in their sway bar graph. I'm just not sure how stiff the c5 rear bar is compared to the c6 bar at each setting.
Old 02-19-2009, 11:04 AM
tcmc5
tcmc5's Avatar
Anyone know how to indentify the ones that don't fit C5s?
Old 02-19-2009, 12:40 PM
redtopz
redtopz's Avatar
Just curious, since some fit both the c6 and c5 (like mine), how can some not fit both cars?
Old 02-19-2009, 01:36 PM
tcmc5
tcmc5's Avatar
Apparently,(I've been told) there were some early C6 bars that do not clear the stock exhaust systems on either C5s or C6s. The design was changed and that fitment issue was resolved.
Old 02-19-2009, 03:06 PM
Wicked Weasel
I believe they would fit the c6 and not the c5 though not 100% sure of that. I can tell you I was sent one of these and the problem was getting around the exhaust on my c5. About the same time I got mine more people started to have issues and that is when gm stopped making them in order to have 1 bar fit both models (which was the plan in the first place).
Old 02-19-2009, 03:21 PM
1ED1
1ED1's Avatar
I have the bar you want 200 plus shipping.
Lancer033
Lancer033's Avatar
Lancer,
JRL
the diameter is the same, so it's got to be pretty close to the same stiffness if not exactly the same...assuming that you are ignoring the adjustments
Old 02-19-2009, 05:45 PM
MattW_VA
MattW_VA's Avatar
St. Jude Donor '07
The bar I have was an "early" C6 bar, it is an adjustable bar (3 holes per end). It was made specifically to fit cars with *no* mufflers. I had to remove the mufflers on my C6 for it to work. I suspect it would fit a C5 without mufflers. They only sold "my" version of the bar for a few months iirc.
my $.02 USD
Old 02-19-2009, 06:46 PM
JRL
JRL's Avatar
I found a bar, thanks everybody for your help.
JRL
To WTB: Rear Adjustable T1 Sway Bar
Quick Reply: WTB: Rear Adjustable T1 Sway Bar
