Sway bar grease question.
I changed out the front bar for a GM T1 bar and greased the GM bar bushings with some brake caliper grease.
It squeaks like granny on her rocker on the front porch.
What do you guys suggest for grease & where do I get it.
Thanks!
__________________
Thanks!
__________________
I actually drilled the chassis mounts out and installed zerk fittings. Now I can grease them with a grease gun.
Richard
Richard
Former Vendor
I have to admit, I haven't done enough plumbing to have used this.
What is the PLUMBING application for this grease?
I have done a bunch of home plumbing. Toilets, faucets, sweat a few pipes.
You don't mean flux I suppose?
dielectric from NAPA big tube cheap. Don't roughen the paint it will wear the bushing faster. Paint will wear off slowly.It needs to move freely and slide or it will bang like most hear banging. after 50,000 miles I have two small chips on my bar and never heard a bang or a rattle.
Shimming properly as DRM told me 9 years ago is critical. The bushing do wear and the OEM will hold grease the best.
this just came up the other day when I was ordering my new front bar.. Have to talk to Sam and see what he said again...
Location: If you don't weigh in you don't wrestle Road America
I always wrap the bars with teflon pipe tape.
The stuff you can get for $.69 at your local hardware store.
Two coats of tape and some silicone grease.
I haven't had one customer with squeeky bars.
