corbeau seat rail loose?
Anyone had this problem, and can it be fixed? My left rail on the drivers side has a lot of play and causes the seat to wobble.
I am actually thinking about just welding them into the adjusted position since I never move the seat anyway. The problem is, moving the seat after it is mounted makes it a lot easier to get the bolts in.
Tim
Tim
It is the sliders-I took them off, a small ball bearing fell out of one, they are bent and messed up.
Luckily, I found out that I can just bolt the seat to the corbeau adapter, without the rail and the position seems to be good. It is also about 3/4 lower which is an added bonus.
I guess my a@$ sliding around at high g's was too much for these sliders.
