C5Z Shock bushings...
Old 02-13-2009, 04:24 PM
autox_vette
autox_vette's Avatar
Default C5Z Shock bushings?
Does anyone have a lead on replacement C5Z upper shock mount bushings/hardware?
I drilled out my stock bushings and washers to put on my JRZ's. Now I'm going to do some testing with some Konis and they have stock sized bayonets, so I need new bushings and washers (stock or poly).
If I remember correctly, the hole size in the frame is oversized with the bushing filling in the space. Haven't seen any aftermarket bushings that seem like they would work right.
Any recommendations (or anyone have a set of stockers they'd be willing to part with)?
Thanks,
Kenton
Quick Reply: C5Z Shock bushings...
