Caravaggio Race Seat (The $1395 One)
Will my fat a$$ fit in this seat? I'm 6'3" tall and weigh 225 lbs with a 39" waist. If any of you big guys have this seat let me know how you fit. Thanks.
I have them in my 02Z... I'm 6'0 195 with a 34-36 in waist. I fit, but I don't have any room to spare. It's actually my motivation to lose a little weight!
The tightest fit for me isn't my waist but on my upper legs/hips.
My problem is wide hip bones. Weight loss won't help that.
But unsupported aluminum seats will fold up in a crash. Aluminum seats need multiple areas of support to support the body. FIA legal seats are designed to take a certain g-load in various directions. Some seat makers like recaro for street seats so some other testing like being dot or tuv compliant. I do not think there is any Aluminum seat that is dot or tuv compliant.
I have 17" Kirkey in my S2000 and they are nice, but too hard to get into and out of for anything but dedicated racing. So they are not an option.
I weigh in at 285 I'm 6' and wear 42 to 44 inch waist. I have more gut than hip so I fit the Caravaggio race seat. It is tight if my hips were bigger I could not fit.
See if you can find someone in your area that will let you sit in one. They are nice seats I even had a Porsche owner asking about them. The nice thing about them is that they use the stock seat rails so you get to keep all the power options.
If you plan to track the car...its not the fit I think you will have a problem with its more the headroom. I'm 185 lbs 6'1" . I mounted my caravagio seat to my seat stock rails. fine w/o a helmet. but with my bell BR-1 NO WAY!
you may have headroom clearance if you go with an aftermarket seat mount ( Pfadt, hardbar etc....) but you will loose the power adjustability.
I agree in that head room is an issue. I just make it and would like a little more clearance. I am going to try taking the bottom cushion out and see how that works.
Nothing like the Caravaggio for a dual purpose seat, but it's there and pretty darn easy to mount properly if you want them for the track...
(Note the seat brace pictures are out of my RX7, not the Corvette)
http://www.petting-zoo.net/photos/Seat-Brace/ -- IO Port sells braces like this; you'll have to get a machine shop to cut off the one shaft collar and weld on another to get this to fit a Hardbar, though. But a seat back brace in combination with the Hardbar seat mounts is ideal for mounting the aluminum seats.
Another item for my list of reason to hate the shop(s) it lived at once it moved to NorCal. Frey Racing and Leadfoot Automotive out here in the SF Bay Area got a good chunk of money and in exchange returned a car that doesn't run, and is still in need of buttoning and dyno tuning... hell, they even blew a motor and I was stupid enough to pay them to replace it.
