Newly designed One Piece brake pads by Carbotech
Supporting Vendor
We have finished our redesign of our C6 Z06 One Piece pad for the front and rear stock calipers (PBR Calipers). We were the first to release the padlets almost four years ago, and then we were the first to release the One Piece over a year ago. That design that we worked with GM on wasn't perfect. That's the same design you see other companies using now.
We set out to redesign the new One Piece all on our own. We wanted to make sure it was perfect and even more user friendly. This new design will drop right into the caliper and you don't have to take out the caliper pins or spring clips. The spring clips are critical in keeping the brake pad square to the rotor surface and ensuring that the pads slide smoothly along the pins. The spring clips also assist in reducing the noise inside the caliper.
This new one piece will make changing pads a lot faster and easier. The newly designed Carbotech One Piece will give longer pad life and a little more bite as well. We are molding the new One Piece pad just like we do with all the C6, C5, and C4 brake pads.
We are also using industry leading NRS technology. If you're not familiar with NRS technology it gives molded pads up to 8 times stronger sheer strength vs. conventional molded brake pads and riveted pads. NRS technology also helps in reducing noise and vibration of the brake pad inside the caliper as well as aiding in longer wearing pads. We use NRS technology on all C6 & C5 front and rear brake pads.
Here is a link to explain further what NRS technology is exactly: http://www.nrsbrakes.com
The new One Piece is available in ALL compounds and are in stock as of right now. All pre-orders will shipped first so please allow for up to seven business days before your order will ship.
Pricing is available on our website: ctbrakes.com
Please feel free to call/pm/post/email me with any questions or comments.
__________________
Danny Puskar
G-LOC Brakes
503 Performance Road
Mooresville, NC 28115
844-927-2537
danny@g-locbrakes.com
Danny Puskar
G-LOC Brakes
844-927-2537
Supporting Vendor
New One Piece pictures
Here is a link to some pictures of our new One Piece design:
http://picasaweb.google.com/carbotec...ePiecePad2008#
I noticed on your website that you must turn your rotors if you have used other pads and switch to these. Is that true even if I only used stock pads before?
John
John
Supporting Vendor
No, not if you have only used OEM brake pads. That is mainly for other high performance racing brake pads. Good question!
decided not to try carbotech race pads - my rotors are DTC-60 polluted
and I don't want to turn them.
Would using street pads for a few hundred miles sufficiently remove
the old compound? Could the rotors be sufficiently cleaned with
emery paper? What effects would be seen if the old material was
not sufficiently removed?
etc
Thanks.
Supporting Vendor
Could you provide more details please? This is the reason why I
etc
Thanks.
etc
Thanks.
The reason is because Hawk and Carbotech use completely different materials in their compounds that are not compatible. If you do not do this then the result can lead to unusual vibrations (brake shudder) and the pads just will not slow down like there are designed to.
Awesome stuff guys. To be honest though, I've tested Hawks and the Carbos back to back with no cleaning of the rotors at all...and they performed flawlessley from start to finish.
Is it possible to install these new one piece pads into the caliper WITHOUT removing the caliper? Is there any way to install the one piece pads from the top of the caliper? I realize that would require the removal of the pins, but just curious if there is enough room to slide them in from the top and then re-install the pad pins.
Supporting Vendor
St. Jude Donor '11,'13
Former Vendor
Q
I am running them on our 06 Vert, DBA one piece rotors, SS lines and brake ducts. XP10/8 compounds because I have used them on another car I use for solo, rare occasion street and TT and they are incredible at everything I throw at them and they have been wearing amazingly well.
They custom made the other cars pads for me, two different sets for different calipers I have used, ordered and received exceptionally quick, great service
I have not taken the vert to the track yet as have not finished the roll bar design but the pads as much as on the other car, not a great deal of dust(and not corrosive) for a comp capable pad. On rare occasion just a little nearly fully stopped squeal which will probably to away with a few more aggressive miles on them, perfect all around pad in my book.
THANKS for making such great pads!
Rick
Rick
Thanks again Gary for the support!!!!!
