Understeer on 07 Z51
I took part in a time attack today, not sure what its called in the US but I think some call it parking lot racing. Anyway basically had to dodge cones and do a 360 etc.
Turns out I had quite a bit of trouble with understeer until I gave it a bit of gas then had trouble with oversteer. Basically I'm wondering if I get some wider tires for the front and rear if it will help me out with grip or should I get some adjustable shocks. I should probably mention I have an ECS supercharger and put down 535 rwhp, so that really didn't help either :-) I even spun out doing a 180 by accident as well. :-) yeah that was kinda scary. Any advice? Also should I be runing in Competitive mode or with TC/AH off?
What you're discussing would be considered an autocross or gymkhana in the states. A couple of questions:
1. How much experience do you have in this form of racing?
2. Can you adjust the boost to limit your power?
Unless you've been doing this for quite a while you'd be well off to read through the tips/hints sticky at the top of this forum.
HTH, and have a good one,
Mike
Mike
assuming you're new to the sport, i'd put money on overdriving the car vs a problem with the suspension, especially with that much power.
otherwise...
softer front suspension (shocks/springs/swaybars)
stiffer rear suspension (shocks/springs/swaybars)
wider front tires
narrower rear tires
more front down force
less rear downforce
otherwise...
wider front tires
narrower rear tires
less rear downforce
What are you using for tire pressures? Have you experimented with that? That's where I would begin.
It was my first time out with this type of racing. Tire pressures were all around 30psi, but rear tires were shot which explains why i lost it. Got them replaced the next day. What kind of tire pressure should I use?
