Interesting Corvette Challenge 90 suspension pics
St. Jude Donor '03 & '05
Look at the aluminum spacer for the sway bar. Guldstrand sells these. What to they do?
Different way to lower Vette
Cc
Probably doesnt change location as the stock unit has a stamped steel spacer there also. Maybe reduces flex or adapts to aftermarket bar mount? Check out the lower a-arm mod to lower the spring pocket.
Not a bad looking caliper. Wonder what kind those are?
Thank you for the link. I had one of the leftover Challenge engines in my C4 for a while. It had been found with several others in a warehouse and they were quickly bought up. It was in the car when I bought it years ago.
Ed
Ed
http://showyourcorvette.com/index.php
Received 8,929 Likes
GM did have a set of experimental 3 piston brake calipers that racers could buy. Sort of like the thick cheek brake rotors GM provided for C5 racers but much harder to get.
Bill
Bill
Former Vendor
There was a lot of testing going on during the challenge days. The challenge was a great deal for both the racer and GM. The engineers worked closely with the teams to make not only the racecar better, but also the street version. The racers had a place to race and the engineers had a place to test. The challenge had some of the best drivers around, put 30 cars in a field and test data comes back very fast.
I don't remember the 3 piston calipers, but I was very young back then.
Randy
Randy
