[FS] Drivetrain from 96 Track Car
Old 11-23-2008, 03:13 PM
Shrek
Shrek's Avatar
Default [FS] Drivetrain from 96 Track Car
Moving on to other interests!
I see a lot of nice track rats for sale, so I thought I would offer up some proven assemblies for someone looking to add a little performance to their current ride.
"SOLD"
Carbed & Stroked LT-4
(478.5 dyno HP @5900 rpm) Aug 07 on eng dyno after rebuild
(413.7 RWHP @5900 rpm) Dec 07 on chassie dyno after 30 laps at CMP
Rebuilt by Abacus Racing in VA Beach, VA. Completed Aug 07 and has just a handful of NCCC/Time Trial laps at CMP, Roebling, and Jefferson circuit at Summit Point. Plus approx. 60 autocross runs.
LT block with Eagle 383 rotating assembly
Fidanza aluminum flywheel
Titan GM Sportsman oil pump
LT-4 heads, ported and decked
1:6 roller rockers
Cam specs
...Duration@ .050: Int.-242 Ex.-248.
...Lift: Int.-.586 Ex.-.581.
...Max head flow: Int.-278 cfm Ex.-187 cfm
GM LT-4 4 barrel intake #24502592
Quick Fuel- Wedge Float road race carburator #Q-750-CT
AED billet aluminum throttle bracket #6600R
Lokar throttle cable #TC1000HT36
Mallory fuel pressure regulator #4309
Dual feed braided fuel line with 0-15 psi gauge
K&N X-Stream air filter assembly
GM water pump #EWP18-1119
MSD ignition box. Digital 6 plus #6520
MSD crank trigger
MSD Blaster 3 coil
MSD distributor #8489
Taylor plug wires
Alt/PS pump/Starter
Stainless long tube offroad headers with sensor bungs
3 inch exhaust with a Dr Gas X-pipe and Flowmaster mufflers #943040
AC delete bracket and pulley
Oil vapor catch can
AUTOGAGE tach with shift light
Phantom series gauges by Auto Meter-Oil press, Oil temp, Water temp,Volts,Fuel
The whole package listed above, ready to bolt in and fire it up! $7500.00 or I will sell any piece seperatly.
ZF Blue Tag Transmission- rebuilt by the ZF Doc
Stock magnesium bell housing with clutch fork
Master and Slave cylinder
Short throw shifter with delrin ****
Stage 3 clutch and pressure plate from Carolina Clutch (what’s left of it)
$1400 or I will sell any piece seperatly.
Dana 44 rear with 3.73 gear (hub to hub)
Vette Brakes HD camber rods with spherical rod ends
Vette Brakes composite spring
20mm sway bar with poly bushings
Vette Brakes HD toe rods with spherical rod ends
Vette Brakes HD 4-link(dog bones) with spherical rod ends
Half shafts/drive shaft/C-Beam
Shocks/Hubs/Knuckles
Stock 96 caliper/NAPA rotors/Hawk pads
Braided lines
$1800.00 or I will sell any piece seperatly.
THANKS FOR LOOKING!!!
Jeff
Old 11-23-2008, 04:06 PM
rasrboy
rasrboy's Avatar
This is a very good car and would hate to see it parted out. If someone wants a fast,reliable C4 car, this is the one to get.
Jeff never took any short cuts on this car and everything is done RIGHT! If I had the extra $ I would buy it in a minute.
Good luck with the sale!
Aaron
Old 11-23-2008, 05:19 PM
Carolina C4 Racer
Carolina C4 Racer's Avatar
Car plus one set of CCW's for $16,00.
For $1600 I'll take it.... But I'm sure there is a ZERO Missing.
Somebody buy it & race it!!!!!
Old 11-23-2008, 05:23 PM
pologreen1
pologreen1's Avatar
what is the hood scoop? that thing is awesome!
Old 11-23-2008, 05:26 PM
Shrek
Shrek's Avatar
Good catch Anthony! Took me all day to type that crap out, that's probably not the only wording I screwd up.
Shrek
Shrek's Avatar
The whole package is Greenwood!
Old 11-23-2008, 06:22 PM
BrianCunningham
BrianCunningham's Avatar
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
Nicest looking carb setup I've seen in a while.
Old 11-24-2008, 07:05 AM
Shrek
Shrek's Avatar
Here's a few pics from Aug 07 during the dyno break in.
Old 11-24-2008, 03:23 PM
BrianCunningham
Love the modded valve covers!
Old 11-24-2008, 04:05 PM
racerwannabe
racerwannabe's Avatar
St. Jude Donor '06
that was my idea! had to go under the alternator bracket with the tall covers... nice car ,,,and extreemly well cared for...
Johnny
life is good!
Old 11-24-2008, 11:11 PM
5abivt
5abivt's Avatar
WTB information on that ac delete bracket !!!! please !
Old 11-25-2008, 06:33 AM
Shrek
Shrek's Avatar
It was on the car when I bought it from Johnny (racerwannabe)
Might want to check with him.
Old 11-26-2008, 03:32 PM
johnnymo63
johnnymo63's Avatar
2021 C4 of the Year - Modified Finalist
C4 of Year Finalist (appearance mods) 2019
If you wind up parting the car, (shame if that happened), how much for the ground effects?
Old 11-26-2008, 06:02 PM
Shrek
Shrek's Avatar
It really depends on how much of it you are interested in. It most likely will go as a package with front and rear bumpers included. There were some holes drilled that would reduce the value of the bumpers without the ground effects attached. As would the hood without the scoop and vents. I wasn't really going to give any thought as to pricing until one of the major driveline components sold. But because I've gotten a few questions about other parts, I will probably go ahead and start offering the rest of the car. When I do, I'll start another thread and list some pricing.
The packages for the body will break down something like this.
1) Front bumper with lighting, rear bumper with lighting, and all skirting
2) Hood with scoop and vents
3) Head light assemblies
4) Windshield fairing with winglets for targ top
Someone has already expressed interest these
5) Doors with glass
6) Targa top
Old 11-26-2008, 07:41 PM
wallyman424
wallyman424's Avatar
man, if i had some extra dough, i'd pick that thing up as a complete package!
Old 11-27-2008, 04:09 AM
lbs90ZR
lbs90ZR's Avatar
Jeff
Old 11-27-2008, 07:18 AM
rfn026
rfn026's Avatar
I think I run the same tires and wheels on my '85 as you have. I'm running 315s in the rear and 275 in the front. The guys at Kuhmo want me to go to 315s all the way around.
What are your wheels and tire sizes?
Richard Newton
101 Projects for Your Corvette 1984-1996
To [FS] Drivetrain from 96 Track Car
Old 11-27-2008, 07:48 AM
Shrek
Shrek's Avatar
Richard Newton
The wheels are 17 X 11.5 CCW classic race with 7.5 backspace. 315 Hoosiers all around.
The rear fenders and hood wheelwells have been slightly flared. The flaring is most visible in my sig picture below.
Old 11-30-2008, 04:08 AM
Mekanic
Mekanic's Avatar
I would really hate to see that beauty parted out, but on the chance it comes to that. Would you separate the headers?
Old 11-30-2008, 10:48 AM
Shrek
Shrek's Avatar
Not quite yet, there is still some interest in the whole package.
As of 12-23-08... I'll sell any part you need!
Quick Reply: [FS] Drivetrain from 96 Track Car
