DRM Spy engine picture
Old 11-20-2008, 06:57 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
Default DRM Spy engine picture
Hope that I don't get in trouble. I just can't hold back
Thanks TPIS for the use of the dyno cell, and the spy photo
Randy
Old 11-20-2008, 07:03 PM
AlwaysInBoost
AlwaysInBoost's Avatar
never seen 8 LM-1's lined up like that... nice!
Old 11-20-2008, 07:08 PM
Axelrod
Axelrod's Avatar
Is Myron still active in the biz ?
Old 11-20-2008, 08:40 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
He retired, but still is in the shop everytime I go there. Picks up the phone and runs parts back and forth. I don't think he will ever slow down.
Randy
Old 11-20-2008, 09:14 PM
ptindall
ptindall's Avatar
Hey, hey! Quit messing around with that stuff and get back to making my oil cooler lines!
Old 11-20-2008, 09:29 PM
dvandentop
dvandentop's Avatar
tell us what we are looking at here
as in specs
gotta do something exciting during this damn winter
Old 11-20-2008, 10:31 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
as in specs
You are looking at the power plant for our lastest turn key package. Not the craziest power in the world, but a good broad power curve. It should power this light weight car just great! Light weight rotating assembly, light valvetrain, middle of the road cam, normal compression ratios, and everything in the book for cooler running.
Winter time, I can find you something fun to do. For not that much money at all, you can score a drive in a Iceracing car. I'm renting a car for a weekend, (I need to drive)
Randy
Old 11-20-2008, 10:41 PM
dvandentop
dvandentop's Avatar
is it going on the frame to the one you posted a few weeks ago??
cant wait to see it all when done!
Old 11-20-2008, 10:43 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
Yep, that is the car.
Randy
Old 11-21-2008, 12:28 AM
rasrboy
rasrboy's Avatar
Old 11-21-2008, 01:12 PM
Bink
Bink's Avatar
Cruise-In V Veteran
St. Jude Donor '09
Are those EGTs for each cylinder?
They look more like AFR sensors but are closer to ports than i would expect.
Old 11-21-2008, 01:29 PM
Z06_BluByU
Z06_BluByU's Avatar
looks mean!!
Old 11-21-2008, 06:15 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
They are O2 sensors. I spoke to Grandpa (Myron) about this today. The biggest difference is the O2 reads the mixture, and there is no guess work where the best heat range is. Back in the day 1600-1800 degrees was the norm. Now with the different cambers, ports, cams, and etc they are much lower. We have learned a lot about intake manifolds, fuel rails and the other issues with the LS engines using these 8 O2s. 13.0 out the pipe is kinda the industry standard. Scary if you ask me, because we know there is a couple lean ones. Tune to the leanest hole, or tune out the lean spot.
This technogly has scored some ASA championships and has helped keep both companies engines healthy.
Randy
Old 11-21-2008, 06:16 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
With your address it took longer to type that into the computer then building the lines. Look for it real early next week. You should have a nice pretty big box at your door step.
Randy
Old 11-21-2008, 06:55 PM
ptindall
ptindall's Avatar
Randy
Old 11-22-2008, 07:24 PM
Bink
Bink's Avatar
Cruise-In V Veteran
St. Jude Donor '09
Randy
Thanks Randy!
To DRM Spy engine picture
Quick Reply: DRM Spy engine picture
