Sway bars, Did GM ever offer or sell 32mm Solid C4 sway bars, front. part 2
Old 11-10-2008, 11:21 AM
steve40th
steve40th's Avatar
St. Jude Donor '03 & '05
Default Sway bars, Did GM ever offer or sell 32mm Solid C4 sway bars, front. part 2
I purchased my sway bars many years ago from Jeff Kopp, and I have the 32 S 26 S set up. But no where on the chart for suspensions is there a 32S sway.
Just curious, as I have measured it and it is a little over 1.25 inches, which is 32mm.
I lost all paperwork and logs years ago (2001) when I moved, so I am curious how I got this bar from Jeff.
Thread 1
http://forums.corvetteforum.com/c4-t...post1567795508
Old 11-10-2008, 11:28 AM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
Thread 1
yes I have them on my GS and got them from DRM in 97. GM stopped production on them.
Old 11-10-2008, 11:29 AM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
I don't think so, but maybe something weird happened.
Randy
Old 11-10-2008, 11:35 AM
RX7 KLR
RX7 KLR's Avatar
Thread 1
If you have a 32mm front it is an Addco bar.
Old 11-10-2008, 11:44 AM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
That should have been the 30MM bar
Randy
Old 11-10-2008, 12:46 PM
ZR1 MK
ZR1 MK's Avatar
Randy
Yes, 30 MM is largest for GM. 32 is actually rounded from 31.75.
Shock valving number?
Old 11-10-2008, 12:47 PM
John Shiels
Randy
yea you are right 30 solid me wrong
Old 11-10-2008, 01:38 PM
steve40th
steve40th's Avatar
I am wondering if there may be a number on the bar. Most manufacturers put something on their product. I know that it came from GM, wether it was theirs or an aftermarket they sold through the dealer.
Old 11-10-2008, 02:07 PM
steve40th
steve40th's Avatar
I AM SO STUPID
Well guess what, GMS Quality assurance isnt all that either.
The bushing is 30mm. I squeezed it real hard and it is 30mm. There is a piece of rubber where they cut the bushing to allow you to put around the bar, and when they cut it was causing it to not compress correctly.
I feel like an Opti SPark
Old 11-10-2008, 02:52 PM
steve40th
steve40th's Avatar
Well anyways, here are the new stiffer OEM bushings.
The poly bushings are offset to pull the bar forward. Wonder why?
Old 11-10-2008, 03:28 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
I know. I have been looking at graph after graph trying to find something close to what you are looking for. I found one, but not a ton of info about what actually was used inside the shock
I see your notes every AM
Randy
Old 11-10-2008, 03:42 PM
ZR1 MK
ZR1 MK's Avatar
Randy
To Sway bars, Did GM ever offer or sell 32mm Solid C4 sway bars, front. part 2
Quick Reply: Sway bars, Did GM ever offer or sell 32mm Solid C4 sway bars, front. part 2
