Need tire sensor reprogrammer ateq?
Old 11-10-2008, 09:44 AM
jstout
jstout's Avatar
Chattanooga Area Events Coordinator
Default Need tire sensor reprogrammer ateq?
Need a tire sensor reprogrammer for my 06 z06 to go from street wheels/tires to track wheels/tires. Any help? Thanks. Jerry
Old 11-10-2008, 10:49 AM
blkc6z51
blkc6z51's Avatar
Check this out.
http://www.bartecusa.com/wheelrite_trackside.htm
Old 11-10-2008, 11:11 AM
H1ghlndr
H1ghlndr's Avatar
Hi,
I use the ATEQ VT10 on my C6Z. Cheap and works fine when I switch back and forth. I ordered directly from them.
Hope it helps,
Bob
Old 11-10-2008, 08:14 PM
BEZ06
Support Corvetteforum!
BEZ06's Avatar
Forum vendor Katech has the Bartec Trackside for $139.95.
As mentioned in a couple other posts, you can get an ATEQ VT10 for $99 (atequsa.com).
Bob
Old 11-11-2008, 09:49 AM
jstout
jstout's Avatar
Does the Ateq work as well as the trackside, or does trackside do other things that ateq doesn't? Why the price difference? Thanks for the reply Jerry
Old 11-11-2008, 01:17 PM
BEZ06
BEZ06's Avatar
Actually the ATEQ does much more than the trackside.
When you order a Trackside you have to tell them what car it's for - they have models for the Vette, Stang, or Viper.
Virtually all GM sensors should be able to be activated with the one for the Vette, but many other sensors can't be triggered with it.
The ATEQ is reported to be a universal tool that will work with ALL current sensors, although it is not upgradeable when new sensors come out. It has 2 buttons. The button on the left will trigger the C6 sensors, and the button on the right works with sensors in many other makes/models of vehicles.
So....in this case, cheaper appears to be better!
Bob
Old 11-11-2008, 09:38 PM
jstout
jstout's Avatar
Hey, thanks alot for the help. Jerry
Old 11-11-2008, 11:23 PM
dvandentop
dvandentop's Avatar
ateq works perfectly used it many times
Old 11-12-2008, 04:19 AM
bobmoore2
bobmoore2's Avatar
So who sells the Atec? Where would I buy one?
Old 11-12-2008, 08:09 AM
BEZ06
BEZ06's Avatar
Get it directly from ATEQ:
http://tpms-usa.store-ateq.com/
Bob
Old 11-13-2008, 10:03 PM
jstout
jstout's Avatar
Thanks Bob, ordered the V10 earlier today. Jerry
To Need tire sensor reprogrammer ateq?
Quick Reply: Need tire sensor reprogrammer ateq?
