Caliper dust boots - upgrade?
Old 11-08-2008, 08:58 PM
froggy47
froggy47's Avatar
Default Caliper dust boots - upgrade?
Anyone have a source for better quality (stock caliper) dust boots? I put some new rears on about 8 months ago & the LR is melted already.
Old 11-09-2008, 06:31 AM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
they need to be wrapped no rubber will survive the heat even one good hot session. Try a search and you will see some pictures here how to do it. Hardbar also makes a nice little shield for tie rod ends. Forget about dust boots and running the track. You need some brake ducting form LGM and DRM for the front.
Old 11-09-2008, 09:46 AM
CHJ In Virginia
CHJ In Virginia's Avatar
I agree with John - forget about the dust boots if you regularly track your car. All you are going to do is burn them up. I ran three years on stock calipers without boots. Just be sure to blow the dust and garbage off the pistons prior to pushing them back in the bore when changing pads.
Old 11-09-2008, 09:50 PM
sleeper02Z06
sleeper02Z06's Avatar
Just pull them off from the get go when you replace calipers, or pull them off of the current caliper. They turn into charred messes anyway. Like posted earlier, just drench the caliper in brake cleaner before pushing the pistons in. I haven't ran dust boots in years.
Joe
To Caliper dust boots - upgrade?
Quick Reply: Caliper dust boots - upgrade?
