Looking for HPDE jack - what do you use?
My trolley jack is getting too old and not dependable. I was looking for a lightweight low-profile to take to track days. Is the $99 Harbor Freight jack the best deal? I looked at Sears and Northern Tool. Sears low profiles are 2x the Harbor Freight price and Northern Tool jack has quality issues. Suggestions?
Torin Aluminum Race Jack with Single Piston Pump — 1 1/2-Ton, Model# T8150121
Torin Big Red is acutally BLUE... at least this model is.
I thought I paid about $80 2 years ago, but current price at Northern is $130. The first jack had issues with holding the load the first time I used it. They sent a replacement ASAP & has served me well for the last 2 seasons. I like the wide front roller, as a hard surface is not always available for changing tires, rotors, etc.
The Sears aluminum jack is great, rugged and backed by Craftsman guarantee, but much heavier and larger for track days. I like the size and weight of the HF, just don’t expect great build quality. I had to take my second one apart to fix the front roller. I used stainless nuts, which seemed to fix the problem. It seems to work OK and is a convenient size and weight. Unfortunately there does not seem to be many options in that size.
IF you are wanting a jack just for track days look at the small metal jacks for around $20 to $40 range. Most are two ton and have a case to store them in. As long as it will go under the side of the car, including a jack puck, it will work fine. They are light and do not take up much space. I would not use one on a daily base though.
I like the look of the sears (for the garage) however the larger one from Harbour Freight is lighter, lifts higher and holds up too!
Use a silver Harbor Freight jack, full size, not small one. Wore one out and now on second. Never failed, just stop lifting very high.
Had a Northern Tool Torin jack which let the car down the first time I used it before I could get the jack stand under it. Jack oil leaked on floor from broken seal or something. Will not buy one again! Good thing I was not under it!
Ed
Ed
