Is 1500 mi too soon for VIR with new motor?
Old 11-05-2008, 03:58 PM
waddisme
Support Corvetteforum!
waddisme's Avatar
Default Is 1500 mi too soon for VIR with new motor?
My new 402 is in and working. There is one track day left at the end of Nov at VIR. My motor will have about 1300 to 1500 miles by then. Is that too soon to try it out? Motor seems to be fine so far with no issues. Thoughts?
Old 11-05-2008, 06:28 PM
coffey
coffey's Avatar
Assuming you changed the oil right after the initial startup, then before you take it to the track. It's not too soon. Drive it like you stole it.
Old 11-05-2008, 06:44 PM
kentz06
kentz06's Avatar
I took my car to Miller Motorsport Park for three continuous days of HPDE/TT starting with 50 miles on the new engine and the Stage 2 ARE oil system. Always made sure oil was up to temp and didn't squeeze out every bit of HP available.
Engine now has ~1500 track miles and ~2000 street miles and is working perfectly.
Dean
Old 11-05-2008, 06:45 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
time to
Old 11-05-2008, 09:16 PM
dvandentop
dvandentop's Avatar
do it before winter here is :
Old 11-05-2008, 09:27 PM
waddisme
waddisme's Avatar
I changed the oil after the 90 min startup and again at 500 mi. I would just like to get some track time in before the winter. Not much going on after Dec 6th. Hopefully some time on the dyno will tell a lot. What little I have pushed it, it feels pretty strong. Definitely different from the supercharger. I am starting to get excited about putting it on the track. Hopefully I can just drive now and not worry about fixing things all the time. It is just too much work to make supercharger work for 30 min track sessions.
Old 11-05-2008, 09:48 PM
GeorgeZNJ
GeorgeZNJ's Avatar
St. Jude Donor '08-'09
I just got back from NJMSP with 975 miles on my new 402.
Old 11-06-2008, 12:30 AM
the blur
the blur's Avatar
gm runs the motor at WOT for 1/2 hour before leaving the plant.
Old 11-06-2008, 01:22 AM
GettReal
GettReal's Avatar
I decided to play it safe and put 100 miles on my car before I drove the hell out of it. My break in vid.. short track - lots of rpm range
http://www.youtube.com/watch?v=tT1Xi7a3jGY
Old 11-06-2008, 03:49 PM
OKsweetrides
OKsweetrides's Avatar
The question actually is...
Drag race tune? Or safe tune?
And then...
Have you been WOT a few times? Or nancy'd around the boulevard?
You don't got anything to worry at this point. If it had blown, it would have a while ago. But it's tune dependent.
Old 11-06-2008, 04:37 PM
waddisme
waddisme's Avatar
I will be getting a dyno tune in about 300 more miles and he knows I road race the car. So anyway, I am signed up for VIR Dec 1.
Thanks.
Old 11-06-2008, 11:59 PM
the blur
the blur's Avatar
when I brought my C4, it was a garage queen. barely any miles on it.
previous owner did maybe 1000 miles per year. 18000 miles on the car.
the car was burning oil, way too much oil.
very unsual for a low mileage car.
I started tracking the car, really using the motor hard. 290-300 oil temps. running to red line every shift.
10000 track miles later, car doesn't burn oil any more.
The rings must have seated from "PROPER" usage.
I don't run it so hard any more, but I wouldn't be afraid of using a motor.
Old 11-07-2008, 12:08 AM
Joy of 6
Joy of 6's Avatar
I drove mine off the showroom floor 505 miles to Thunderhill and did 2 hard track days and now at 40k it still runs like a champ. Doesn't burn any oil at all.
Old 11-07-2008, 06:58 AM
AU N EGL
AU N EGL's Avatar
Break the motor in as you plan to drive it
Old 11-07-2008, 12:14 PM
RedLS6
RedLS6's Avatar
Received 1,729 Likes on 783 Posts
Should be OK to run it at 1500 miles .... will see you there on Dec1!
Old 11-07-2008, 01:21 PM
undertaker
undertaker's Avatar
Location: ECS : WTF did you break now and HTF did you break it this time
1500 will be fine, I've put 2 new motors right onto the track, about 150 miles on my forged turbo motor, and about 300-350 on my NA 427 before it hit the road courses. With teh 427 I was actually smart and had to 'convince' a buddy to drive my car up there for me to break it in, and I trailer up his h/c 346 car. I get a call 3/4's of the way up on a 250 mile trip and he's saying OMG this thing is absolutely nuts.....I said I remember to tell you to keep it under 5 grand right?
He said um, nope....
Well it passed its tests with flying colors
Old 11-07-2008, 01:59 PM
Timz06
Timz06's Avatar
You'll hear a million different answers to this one...but 1500 is already quite a few miles, so I wouldn't worry about that at all, personally.
Tim
Old 11-07-2008, 07:41 PM
waddisme
waddisme's Avatar
Thanks!
Old 11-08-2008, 08:30 AM
varkwso
varkwso's Avatar
Tim
Have fun at VIR
To Is 1500 mi too soon for VIR with new motor?
Quick Reply: Is 1500 mi too soon for VIR with new motor?
