oil cooler????
Old 11-04-2008, 08:22 PM
sdef
sdef's Avatar
St. Jude Donor '10
Default oil cooler????
There are so many to choose from. Which ones have you had good luck with, and which should I stay away from? What features should I look for in better oil coolers?
It will be going in a 2002 zo6 for track racing.
Old 11-04-2008, 10:00 PM
J.R.
J.R.'s Avatar
I have a PFADT external oil cooler with a De Witts radiator and find that it is approx 20-25 deg less oil temp than with a Ron Davis with a built in cooler. I feel the difference is not the radiators but the external oil cooler and location (front lic plate area). refer www.pfadtracing.com
Old 11-04-2008, 10:51 PM
sperkins
sperkins's Avatar
I recently installed an external cooler on my '03 Z6. I refused to pay the exorbitant amount the vendors are charging for their kits. I bought the cooler, hoses, and -AN fittings from Summit Racing and bought the adapter block from Lingenfelter. I fabricated the mounting brackets in about 10 minutes. I saved a little over a $100 doing it this way and have had great results. Here's a few pics:
Don't worry, the bolts are NOT going through the condensor.
Old 11-05-2008, 07:30 AM
AU N EGL
AU N EGL's Avatar
Trans cooler left - oil cooler right
Old 11-05-2008, 07:42 AM
CHJ In Virginia
CHJ In Virginia's Avatar
I am using the DRM kit that is found on their web site. Great kit, all the bits and pieces, brackets and adaptors are included. It took me about 3 hours to install on my back on the garage floor. If I had used a lift time would have been about 2 hours. I was running 290-300 Deg oil temps at VIR in August. After kit install the highest temp I saw on a 95 Degree August day was 260. Well worth the $ from a longevity standpoint.
Old 11-05-2008, 07:43 AM
levettegrl
levettegrl's Avatar
Cruise-In IV Veteran
I have an integrated radiator/oil cooler from DRM
Oil temps used to be 300, run around 240 now on a hot day, best thing I ever put on my '02Z06
Old 11-05-2008, 08:34 AM
VetteDrmr
VetteDrmr's Avatar
Received 1,394 Likes on 747 Posts
I put an external oil cooler in a few years ago to get my temps down from 280-290. I made up an install guide you can find here:
http://www.brazosrivercc.com/Tips.html
HTH, and have a good one,
Mike
Old 11-06-2008, 04:51 PM
waddisme
Support Corvetteforum!
waddisme's Avatar
That will be my winter project.
To oil cooler????
Quick Reply: oil cooler????
