C5 Z06 - Super Stock - side molding removal
Old 11-03-2008, 07:44 PM
Chewbacca
Cruising
Chewbacca's Avatar
Default C5 Z06 - Super Stock - side molding removal
I'm looking to get an '03 - '04 Z06 next year to supplement the Camaro in my cone dodging endeavors. Problem is that I hate the look of the side molding on the Corvettes.
According to Doug Gill, I can legally remove the molding without having to touch anything else if it was a stand alone option (which from my understanding it was).
Sooooo... was this a stand alone option? If anybody has a copy of their order sheet showing that it was stand alone (if this is indeed the case) I'd really appreciate it if I could get a copy of that for supporting documentation.
Thanks.
Old 11-03-2008, 07:55 PM
LehmanZ06
LehmanZ06's Avatar
You can remove it----no worries-----stand alone option. Comes off with a heat gun---
You're good to go---
Old 11-03-2008, 08:06 PM
Chewbacca
Cruising
Chewbacca's Avatar
Thanks Dave.
I figured they would come off easy with maybe only a little heat. The moldings came off my truck with only a warm day and some peeling.
Due to my lack of speed to this point in the Camaro and the likelihood of the same condition in a Corvette, I wasn't really worried about getting protested. But I also want to be 100% legal because I do run the big events and there's always one in the bunch somewhere....
AverageVetteNut
AverageVetteNut's Avatar
Cruise-In 9-10 Veteran
CI-X Auto-X Champ (race tires)
St. Jude Donor '07-'09
+1 on the great Mr. Lehman's assesment
since it was available on it's own, its free to remove ( or add for that matter )
Old 11-03-2008, 08:12 PM
xilr8n
xilr8n's Avatar
Order guide with the $150 option B84
http://z16.org/ordergd.php
Old 11-03-2008, 08:29 PM
xsiveone
xsiveone's Avatar
If anything, the BSM's are more aerodynamic, so removing them should put you at a disadvantage.
Old 11-03-2008, 08:30 PM
LehmanZ06
LehmanZ06's Avatar
I sold mine to a proctologist----
he told me he was going to stick it up someone's....
Old 11-04-2008, 06:30 AM
AverageVetteNut
tailpipes?
To C5 Z06 - Super Stock - side molding removal
Quick Reply: C5 Z06 - Super Stock - side molding removal
