Changing C6 Z51 engine oil cooler to C6 Z06
Is changing my engine oil cooler on a C6 Z51 to the larger C6 Z06 worth the effort? Should I buy aftermarket? Which one and does anyone have instructions on the change? I see 290 degrees after about 20 min. of track time.
An external oil cooler made a big difference in lowering my track temps. Typically it's installed with an aftermarket radiator (Ron Davis/Dewitts). Don't get a combined radiator/oil cooler.
There are lots of choices of coolers (you need not get a GM model). You also have the option of a one or two stage. Ergo, one or two run in succession for more cooling.
Pictured is my set up:
1. for street/track car(one stage/later modded to a two stage)
2. for track only car (two stage)
On plate/fin type coolers its best to mount them with the inlet/outlet upward. That purges all air and the cooler is working at its full efficiency. Any other arrangement and there is a good chance that not all the cooler is being used. Worst mounting is with the ports down. Just imagine. The oil will take the path of least resistance. With the ports up gravity doesn't allow the oil to take the first few rows until the ones beneath have been purged of air.
FM
I had the small OEM C6 Z51 oil cooler replaced with the OEM Z06 Oil cooler. The Z06 cooler is around 2.5X longer. I purchased my cooler used from Katech. Definitely one of the cheaper cooling upgrade options, however it does not compare to a good aftermarket cooler. Ultimately I still see temps get to 285-290 after 30 minutes of running between 3500 and 6500 RPM.
Assuming you drive this car on the street, I would put in a DRM combo oil cooler/rad (or like brand). If you are going through the trouble (not really a tough thing to do) change the radiator too with the combo unit.
For the street I would not mess with the radiator/oil cooler(OEM should work fine). For RR go external. Plus a radiator without the internal oil cooler has more cooling capacity. If you go to Dewitt's website he has posted some notes that suggest the same for RR.
Good luck.
Anyone have any thoughts on the Lingenfelter unit? It measures 11"x4"x2" and mounts to the front aluminum engine/suspension cradle with the custom LPE bracket.
Thanks for all the feedback. My original post should have stated:
- I am an aggressive driver and normally come in or slow down when my oil temp hits 290
- I have a 2008 C6 Z51 with the small cooler that is primarily for the track.
I realize the best set-up is a large external cooler with a new radiator, but I am trying to find the most economical solution in these difficult economic times. It seems tracking a car and economical are two concepts that do not play well together. I have to save somewhere since I go through a set of Cobalt pads, rotors and Mobil 1 oil change every weekend on the track. (I might get 2 weekends on a set of R888s)
I think it might. Running your car on track and baking the engine eventually might buy you a new engine, ring job or other fun stuff. Engine cooling equipment is a smart insurance policy for your car.
Unfortunately, you will probably bump up into the same issues for a tranny and diff cooler as you get more seat time and start pushing the car harder.
Why did we pick this stupid sport? Because it's too damn much fun!!!!
Good luck.
I've tracked (RR) both set ups. A Dewitt's combo and a Ron Davis with an external oil cooler. The former didn't do that much compared to OEM. The latter lowered temps 20 degrees.
Good luck.
Good luck.
Webz, it sounds like we both have similar cars and you have done what I was going to do, with little positive result. So do I just keep my Z51 OEM small external cooler and just buy a noncombo radiator? Isn’t there an internal cooler in the radiator already?
On the 08 the differential cooler is integrated in the radiator so you would have to take that into account when looking into after market cooling solutions. I believe the change to the Z06 cooler was good for 10 to 15 degrees, which I view as a positive move. In addition the car remains streetable, and the change did not effect the other cooling systems.
