Tire recommendation?
Old 10-09-2008, 03:41 PM
KILR-RYD
KILR-RYD's Avatar
Default Tire recommendation?
If you are looking to do 4-5 HPDEs or more and also drive your car daily in dry or wet, what is a good compromise for both things? please advise.
I was told Nitto Invos, but then when i typed that in google, some other forums mentioned them as not being as good.
Old 10-09-2008, 04:01 PM
waktasz
waktasz's Avatar
Do you want a street tire or a DOT-R tire?
Old 10-09-2008, 04:32 PM
KILR-RYD
KILR-RYD's Avatar
Street, DOT-Rs I cant use on street right, so I want something i can use on both, track & street.
Old 10-09-2008, 04:40 PM
waktasz
waktasz's Avatar
You can use some Rs on the street. Toyo RA-1 for example is one. I got about 15,000 miles out of a set of Hankook z211 c50 compounds also.
Old 10-09-2008, 05:23 PM
KY-Traveler
Support Corvetteforum!
KY-Traveler's Avatar
CI 7-8 Veteran
St. Jude Donor '07-'08-'09
I used BFGoodrich g-Force KDW's from Tire Rack..
I would talk to Tire rack to see what else they might recommend.
Old 10-09-2008, 05:44 PM
Aardwolf
Aardwolf's Avatar
Falken RT-615!
Old 10-09-2008, 09:11 PM
Gray Ghost GS
"AlohaC5" Senior Member
Gray Ghost GS's Avatar
BF Goodrich g-Force KDs or Falken Azenis RT-615. Great street tires that perform exceptionally well on the track.
Old 10-09-2008, 09:44 PM
argonaut
argonaut's Avatar
I'd second the Falkens as a good compromise, especially for the price. Used them all spring on track, street and autoX. I was on Pocono in the rain with them and they worked pretty well.
Old 10-10-2008, 05:28 AM
the blur
the blur's Avatar
kumho victor racers.
Old 10-10-2008, 09:39 AM
City Goat
City Goat's Avatar
I f'n LOVE my Nitto 555R2s
6 track days on them and about 6k miles total. Just about to the wear bars. I'll definitely see another 4k out of them. 275/40/17 and 305/35/18....
To Tire recommendation?
Quick Reply: Tire recommendation?
