First C5 Z06 Auto-x: a few impressions/questions
I just completed my first auto-x in my new (to me) '03 Z06. My past auto-x experience was in a DSP MGB and a bit in my '95 Impala SS (talk about "weight transfer ". This is kind of a ramble
First impression was...fast. Very fast. I'd been into it a little bit off the track, but getting unwound (through 2nd, anyway) on the course really shows how fast these beasts are. I didn't really feel that the car had any handling "vices", other than an intolerance for a heavy foot in corner transitions (what a surprise). I was really surprised at how light and agile the car felt considering it's size. The stock brakes were incredible, and I didn't find the anti-lock all day, which I recognize means that I can accelerate a little deeper and brake a little harder. I can definitely see that some sort of better harness is required as well as some race tires. I have a 2nd set of Z06 wheels and I will be running race rubber next year.
Questions:
One of the biggest changes for me in learning auto-x was learning to look (and think) ahead - I'm finding in the Z06 I gotta look (and think) WAY ahead. I was behind the car the whole day. Thoughts on how to approach this other than "yep, that's what you need to do"?
I have to admit that once I hit 2nd gear I was pretty much treating the car like it had an auto; I shamefully don't remember touching the clutch even once during the runs, but I also don't recall the R's dropping below about 2K. I'm also going to practice some 2nd gear starts. I feel like this is a really, really dumb question...but should I be hitting the clutch every time I hit the brakes?
Finally, the approach seems to be "point and squirt", which is very different than what I had to do in the MGB Accelerate hard, brake late, hard and straight, turn, accelerate out. Am I missing something here?
Go easy on me - I'm just learning this beast
Questions:
I had my 1st autocross in my new to me Z06 this weekend as well... 2002
I went from a DS Cobalt SS... so I can relate to the same issues....
I found myself thinking about HOW to look ahead better with how much more quickly things come up.
I would say that you shouldn't need to be touching the clutch unless you are trying to settle/un-settle the car, but you can do that with the brakes ( i would think.. ) as well. I didn't touch mine either.
I had the TC/AH turned off as well, and there's alot of reward for patience and throttle managment from what I can tell. I had an open diff in the SS, so I'm used to being that way, so it was a quick adjustment for me.
I am looking forward to the last auto-x of the year this weekend... running it in our "street tire index" just to have some fun.
Good luck!
Good luck!
1 Post
Getting into 2nd and keeping it there is perfect unless you are running in a really, REALLY tiny lot with tight 180s. Don't worry about going back down to first, especially if you are new. The chance that you will blow the shift and lose time is bigger than the small amount you might gain by accelerating in first.
And definitely keep your foot off the clutch when on the brakes. I hope you aren't doing this on the street. It's a good way to end up backwards if you end up doing it in the rain or something.
Keep your eyes moving.
Forget about a second gear start, except maybe in the rain. West coast people seem to like this stategy because Dietz has used it, but I've heard him say he only uses it when there is no start at all...whatever that means.
Two strategies on the start: short shift to second at the first lift or stay in first as long as possible to redline. The course layout will determine which strategy you choose.
Good luck and stay safe!!
You are correct in saying the Z is surprisingly agile. I run with SCCA and the local PCA chapter and they both have a habit of setting up their courses with very tight corners. The PCA club members have even said they do that on purpose to hinder the Corvettes that show up. One thing about our long wheel base cars is their tendency to understeer badly. You can compensate for this by either braking sooner to kill speed or trail brake into the corner to help transfer the weight to the front tires. I have found that the AH/TC absolutely kills time on an autox course. You shouldn't be using the clutch unless you are too far down below your torque curve to be able to get back up to speed. Put on a set of DOT or R compounds which are allowed in SS and you'll kick everyones tail.
I have a couple of AutoX videos on my YT page:
http://www.youtube.com/user/68ray
Yes you need to look ahead, but the bigger problem in the Z06 is target fixation, IMHO. Things happen soooo much faster in the Z that there's a tendency to fixate on a key cone, and once you get to it you look up late and now you're behind for the next element.
Here's a good learning video for you on the pain of over driving. Watch the video first then read the lesson below:
http://www.youtube.com/watch?v=RtxPoDMK-yk
On that run I lost close to 2 seconds because of overdriving 2 corners.
At 32 seconds you can hear me squirt the gas. That squirt pushed me wide on the next turn which made me late to the gas. I should have been on the gas at 34 seconds, instead I'm fighting to get the car back on line and don't accelerate strong until about 37 seconds.
The second lesson is at 52 seconds where I squirt the gas again, which now makes me late all the way until 59 seconds. I should have been accellerating at 54 seconds coming out of the slalom and again at 57 seconds heading into the finish runway.
Those two moments of over-agressive throttle application cost me almost 2 seconds on that run. Just because you can squirt doesn't mean you should.
Questions:
Welcome to the red-headed step-child of road racing!
Mike
For me, the course walk is the most important part of the day. As I walk, I stop at corner entry and take a mental picture, then say out loud (to myself) I should be looking at that cone over there. The cone you should be looking at is usually in the next corner, or further ahead.
I walk the course until I can close my eyes and picture driving the entire course and recall which are the key cones that I will have to look for. If I cant do this by the first run, it's probably going to be a poor day.
Chris Shay
Chris Shay
Chris Shay
Chris Shay
All great tips!
(And another congratulations!)
Then video that, and watch it until your second outing...
I was thinking more about doing something "Cool Runnings"-esque and just doing a slow(er) walk to get it all in my head...and then driving it in my head. We'll see.
2nd autocross today - and 1st one with the traction control off. I'd have to say that I should have approached this from "going slow to go fast" given the change, but I did the opposite on the first 2 runs and experienced my first 2 spins in the Z06 I did finally get it figured out and turned in a decent time for street tires. Still strugged with getting the course firmly in my head...something I need to continue to work on.
That was the last course of the year - I've got my development plan laid out for next year which is basically to run as many events as I can and ride with/take riders on as many as possible.
THANKS to everyone for their advice!
