Are these tires toast? Kuhmo V710s
Old 09-29-2008, 04:04 PM
turbo50mike
turbo50mike's Avatar
Default Are these tires toast? Kuhmo V710s
A couple of things - I am right at the wear bar, but across the tire, the 'dimples' still have some depth in them.
Second, it looks like I cut the surface of the tire while pulling on the trailer - The reason I think the trailer did it is because if it happened on the track, I think I may have seen whatever it was I ran over, and I think any more time on the track with that cut would have smoothed out the edges.
The cut is only about 1/8", and it doesn't go 'in', it's at a slight angle. I don't see cords or steel or anything like that - And it hasn't lost any air....
Old 09-29-2008, 04:12 PM
95jersey
95jersey's Avatar
Besides the seperation issue with these tires, they have definite life left in them. I have used 710's until there were no discernable groves. So my advice is run them till they cord and these are not at that point. You can also flip them around and run the grooves on the outside of the tread with no issues at all to increase the life of the tire.
Old 09-29-2008, 04:14 PM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
Those are junk. I'll pay the shipping to send them to me to dispose of them properly.
Old 09-29-2008, 04:23 PM
RX7 KLR
RX7 KLR's Avatar
Tread splice gap, not a big deal. I had it happen to one tire just a few weeks ago at the Solo Natls, first time I have had it happen in over three years. I noticed it after the first day of competition on one of my rears, so I moved it to the front the next day, the splice started to close up.
Anytime you see this starting try moving the tire to another location on the car, or so it is going the other direction, this should prevent it from getting worse.
Old 09-29-2008, 04:28 PM
turbo50mike
Thanks for the advice...I'll try flipping them, and see if it'll seal up..
I'm going to use these for one more day this Friday, and if you want them, they're yours for the price of shipping. There will be 4- 315/35/17's.
Old 09-29-2008, 04:32 PM
mikahb
Vetteless
Support Corvetteforum!
mikahb's Avatar
St. Jude Donor '09
Yup - us budget racers who run pre-owned Kumho's have to pay close attention to this. I swap sides of the car on a race weekend every single session - keeps the seam delamination nicely at bay. Other than that, those tires are spring chickens!!
RX7 KLR
RX7 KLR's Avatar
No need to flip it or get rid of them. If it was left move it to the right side - or if you have a square setup move it front to rear, or vise versa. All you need to do is change the direction of the tires rotation. If you were to flip it but then still have it work the splice in the same direction it will still open.
Old 09-29-2008, 04:40 PM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
Deal.
Old 09-29-2008, 04:49 PM
Fastguy
Fastguy's Avatar
St. Jude Donor '03-'05
I have purchased tires that were more worn than that.
Old 09-29-2008, 06:04 PM
gonzalezfj
gonzalezfj's Avatar
Buy Hoosiers and you will not have to worry about the tread splice opening up.
Frank Gonzalez
Old 09-29-2008, 07:29 PM
ghoffman
ghoffman's Avatar
Cruise-In II Veteran
Frank Gonzalez
Agreed, that scares the crap out of me.
Old 09-29-2008, 07:50 PM
the blur
the blur's Avatar
years ago we called that "The Kumho Crack". It was very common on the Victor Racers.
Run them till they cord, and then run them 1 more session after that until the steel belts show.
I have never seen 1 delaminate from the crack.
Old 09-29-2008, 08:05 PM
R Mackow
R Mackow's Avatar
This crack seems to be common on V710s. My first set on V710s after one autox did this. I almost sh*t.
Contacted dealer and Kumho who reasuured me they were OK. A couple of years ago Kumho had a recall on certain tires and mine were not part of the recall.
I ran this until I corded them.
Old 09-29-2008, 08:14 PM
RedLS6
RedLS6's Avatar
Received 1,729 Likes on 783 Posts
I've gone through quite a few sets of Kumho 710s, and I think most of them developed the tread splice. Those are still good - run 'em!
Old 09-29-2008, 09:11 PM
Datawiz
Datawiz's Avatar
CI-7-8-9-10 Veteran
Cruise-In IX AutoX Winner
St. Jude Donor '05-'06-'07-'08-'09-'10-'11,'19,'22
St. Jude/CI Name Tag Designer
Frank Gonzalez
I just have to worry about my Hoosiers cording the shoulders after 4 runs.
Old 10-01-2008, 11:27 AM
RUN4CVR
RUN4CVR's Avatar
Are those cuts from running over Saleen Mustangs at NJMP?
Old 10-02-2008, 10:47 AM
Fastguy
Fastguy's Avatar
When they look like this, its time to dump them.
Old 10-02-2008, 11:00 AM
the blur
the blur's Avatar
you can flip those tires over, and get another session out of them.
To Are these tires toast? Kuhmo V710s
Quick Reply: Are these tires toast? Kuhmo V710s
